As an NVIDIA Elite Partner, e-con Systems has been working on high-performance cameras and compute solutions tailored for the new Jetson Thor platform. I wanted to share an overview for those exploring multi-camera and AI-heavy workloads.
Camera Solutions Optimized for Jetson Thor
USB cameras
Plug-and-play evaluation for image quality testing and rapid prototyping. Useful for fast iteration during early-stage development. -
RouteCAM Ethernet cameras (ONVIF compliant)
Industrial-grade robustness + IP-based streaming. Good fit for factory automation, surveillance, and scalable ITS deployments.- 10G Holoscan Camera Solutions
Built on our HSB board with FPGA-based TintE ISP for ultra-low latency, high-throughput imaging.-
Supports sensor fusion (up to 20 MP)
Frame sync across multiple sensors
Compatible with Sony IMX715, IMX568, IMX900, onsemi AR0234, AR2020, Sony ISX031, and more
ISP Flexibility
Developers can choose between Userspace ISP, NVIDIA Argus ISP, or TintE ISP depending on latency, image quality, or compute trade-offs.
ECU Platforms with Jetson Thor
Compact, production-grade compute units integrating Thor for demanding environments:
Multi-camera ingest with deterministic I/O
Rugged thermal design
Suitable for robotics, humanoids, industrial automation, mobility systems, and medical devices
👉 For those already experimenting with Jetson Thor:
How are you handling multi-camera synchronization and bandwidth?
Are you relying more on Argus ISP or exploring custom FPGA/ISP pipelines?
More details here: **e-con Systems – High-Performance Cameras & Compute for NVIDIA Jetson Thor.
