The tool is for desktop GPUs. For Jetson platforms, you can run sudo jetson_clocks to run GPU engine at maximum clock.
After running sudo jetson_clocks , will this message no longer appear? Is it necessary to address this error?
After running sudo jetson_clocks, GPU engine will be running in maximum clock
You can get optimal throughput in the setting.
nvidia-modeset is not supported on Jetson platforms. Please not run it.
