Hi DaneLLL,
Thank for your reply. After refer that topic, I tried to modify to encode raw image capturing from camera. But I can not see any callback event
Can you help me review this code
* Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* * Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* * Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the distribution.
* * Neither the name of NVIDIA CORPORATION nor the names of its
* contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS ``AS IS'' AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
* PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
* CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
* PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
* PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY
* OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <sys/stat.h>
#include <sys/mman.h>
#include <fcntl.h>
#include <errno.h>
#include <stdlib.h>
#include <signal.h>
#include <poll.h>
#include <iostream>
#include <fstream>
#include <Argus/Argus.h>
#include <EGLStream/EGLStream.h>
#include <EGLStream/NV/ImageNativeBuffer.h>
#include "NvVideoEncoder.h"
#include <NvApplicationProfiler.h>
#include "NvEglRenderer.h"
#include "NvUtils.h"
#include "NvCudaProc.h"
#include "nvbuf_utils.h"
#include "camera_v4l2_cuda.h"
static bool quit = false;
using namespace std;
using namespace Argus;
// Constant configuration.
static const int MAX_ENCODER_FRAMES = 5;
static const int DEFAULT_FPS = 30;
static bool DO_STAT = true;
static uint32_t ENCODER_PIXFMT = V4L2_PIX_FMT_H264;
static Size STREAM_SIZE (1280, 720);
static bool encoderCapturePlaneDqCallback(
struct v4l2_buffer *v4l2_buf,
NvBuffer *buffer,
NvBuffer *shared_buffer,
void *arg);
bool encoderOutputPlaneDqCallback(struct v4l2_buffer *v4l2_buf,
NvBuffer * buffer,
NvBuffer * shared_buffer,
void *arg);
static void abort(context_t *ctx);
static void
print_usage(void)
printf("\n\tUsage: camera_v4l2_cuda [OPTIONS]\n\n"
"\tExample: \n"
"\t./camera_v4l2_cuda -d /dev/video0 -s 640x480 -f YUYV -n 30 -c\n\n"
"\tSupported options:\n"
"\t-d\t\tSet V4l2 video device node\n"
"\t-s\t\tSet output resolution of video device\n"
"\t-f\t\tSet output pixel format of video device (supports only YUYV/YVYU/UYVY/VYUY)\n"
"\t-r\t\tSet renderer frame rate (30 fps by default)\n"
"\t-n\t\tSave the n-th frame before VIC processing\n"
"\t-c\t\tEnable CUDA aglorithm (draw a black box in the upper left corner)\n"
"\t-v\t\tEnable verbose message\n"
"\t-h\t\tPrint this usage\n\n"
"\tNOTE: It runs infinitely until you terminate it with <ctrl+c>\n");
static bool parse_cmdline(context_t * ctx, int argc, char **argv)
int c;
if (argc < 2)
print_usage();
exit(EXIT_SUCCESS);
while ((c = getopt(argc, argv, "d:s:f:r:n:cvh")) != -1)
switch (c)
case 'd':
ctx->cam_devname = optarg;
break;
case 's':
if (sscanf(optarg, "%dx%d",
&ctx->cam_w, &ctx->cam_h) != 2)
print_usage();
return false;
break;
case 'f':
if (strcmp(optarg, "YUYV") == 0)
ctx->cam_pixfmt = V4L2_PIX_FMT_YUYV;
else if (strcmp(optarg, "YVYU") == 0)
ctx->cam_pixfmt = V4L2_PIX_FMT_YVYU;
else if (strcmp(optarg, "VYUY") == 0)
ctx->cam_pixfmt = V4L2_PIX_FMT_VYUY;
else if (strcmp(optarg, "UYVY") == 0)
ctx->cam_pixfmt = V4L2_PIX_FMT_UYVY;
else
print_usage();
return false;
break;
case 'r':
ctx->fps = strtol(optarg, NULL, 10);
break;
case 'n':
ctx->save_n_frame = strtol(optarg, NULL, 10);
break;
case 'c':
ctx->enable_cuda = true;
break;
case 'v':
ctx->enable_verbose = true;
break;
case 'h':
print_usage();
exit(EXIT_SUCCESS);
break;
default:
print_usage();
return false;
return true;
static void
set_defaults(context_t * ctx)
memset(ctx, 0, sizeof(context_t));
ctx->cam_devname = "/dev/video0";
ctx->cam_fd = -1;
ctx->cam_w = 1280;
ctx->cam_h = 720;
ctx->frame = 0;
ctx->save_n_frame = 0;
ctx->g_buff = NULL;
ctx->renderer = NULL;
ctx->got_error = false;
ctx->fps = 30;
pthread_mutex_init(&ctx->queue_lock, NULL);
pthread_cond_init(&ctx->queue_cond, NULL);
ctx->enable_cuda = false;
ctx->egl_image = NULL;
ctx->egl_display = EGL_NO_DISPLAY;
ctx->enable_verbose = false;
sprintf(ctx->cam_file, "encode.mp4");
ctx->enc_output_plane_buf_queue = new queue < nv_buffer * >;
static nv_color_fmt nvcolor_fmt[] =
// TODO add more pixel format mapping
{V4L2_PIX_FMT_UYVY, NvBufferColorFormat_UYVY},
{V4L2_PIX_FMT_VYUY, NvBufferColorFormat_VYUY},
{V4L2_PIX_FMT_YUYV, NvBufferColorFormat_YUYV},
{V4L2_PIX_FMT_YVYU, NvBufferColorFormat_YVYU},
static NvBufferColorFormat
get_nvbuff_color_fmt(unsigned int v4l2_pixfmt)
for (unsigned i = 0; i < sizeof(nvcolor_fmt); i++)
if (v4l2_pixfmt == nvcolor_fmt[i].v4l2_pixfmt)
return nvcolor_fmt[i].nvbuff_color;
return NvBufferColorFormat_Invalid;
static bool
camera_initialize(context_t * ctx)
struct v4l2_format fmt;
// Open camera device
ctx->cam_fd = open(ctx->cam_devname, O_RDWR);
if (ctx->cam_fd == -1)
ERROR_RETURN("Failed to open camera device %s: %s (%d)",
ctx->cam_devname, strerror(errno), errno);
// Set camera output format
memset(&fmt, 0, sizeof(fmt));
fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
fmt.fmt.pix.width = ctx->cam_w;
fmt.fmt.pix.height = ctx->cam_h;
fmt.fmt.pix.pixelformat = ctx->cam_pixfmt;
fmt.fmt.pix.field = V4L2_FIELD_INTERLACED;
if (ioctl(ctx->cam_fd, VIDIOC_S_FMT, &fmt) < 0)
ERROR_RETURN("Failed to set camera output format: %s (%d)",
// Get the real format in case the desired is not supported
memset(&fmt, 0, sizeof fmt);
if (ioctl(ctx->cam_fd, VIDIOC_G_FMT, &fmt) < 0)
ERROR_RETURN("Failed to get camera output format: %s (%d)",
if (fmt.fmt.pix.width != ctx->cam_w ||
fmt.fmt.pix.height != ctx->cam_h ||
fmt.fmt.pix.pixelformat != ctx->cam_pixfmt)
WARN("The desired format is not supported");
ctx->cam_w = fmt.fmt.pix.width;
ctx->cam_h = fmt.fmt.pix.height;
ctx->cam_pixfmt =fmt.fmt.pix.pixelformat;
INFO("Camera ouput format: (%d x %d) stride: %d, imagesize: %d",
fmt.fmt.pix.width,
fmt.fmt.pix.height,
fmt.fmt.pix.bytesperline,
fmt.fmt.pix.sizeimage);
return true;
static bool createVideoEncoder(context_t * ctx)
int ret = 0;
ctx->m_VideoEncoder = NvVideoEncoder::createVideoEncoder("enc0");
if (!ctx->m_VideoEncoder)
ERROR_RETURN("Could not create m_VideoEncoderoder");
if (DO_STAT)
ctx->m_VideoEncoder->enableProfiling();
ret = ctx->m_VideoEncoder->setCapturePlaneFormat(ENCODER_PIXFMT, STREAM_SIZE.width,
STREAM_SIZE.height, 2 * 1024 * 1024);
if (ret < 0)
ERROR_RETURN("Could not set capture plane format");
ret = ctx->m_VideoEncoder->setOutputPlaneFormat(V4L2_PIX_FMT_YUV420M, STREAM_SIZE.width,
STREAM_SIZE.height);
if (ret < 0)
ERROR_RETURN("Could not set output plane format");
ret = ctx->m_VideoEncoder->setBitrate(4 * 1024 * 1024);
if (ret < 0)
ERROR_RETURN("Could not set bitrate");
if (ENCODER_PIXFMT == V4L2_PIX_FMT_H264)
ret = ctx->m_VideoEncoder->setProfile(V4L2_MPEG_VIDEO_H264_PROFILE_HIGH);
else
ret = ctx->m_VideoEncoder->setProfile(V4L2_MPEG_VIDEO_H265_PROFILE_MAIN);
if (ret < 0)
ERROR_RETURN("Could not set m_VideoEncoderoder profile");
ret = ctx->m_VideoEncoder->setLevel(V4L2_MPEG_VIDEO_H264_LEVEL_5_0);
if (ret < 0)
ERROR_RETURN("Could not set m_VideoEncoderoder level");
ret = ctx->m_VideoEncoder->setRateControlMode(V4L2_MPEG_VIDEO_BITRATE_MODE_CBR);
if (ret < 0)
ERROR_RETURN("Could not set rate control mode");
ret = ctx->m_VideoEncoder->setIFrameInterval(30);
if (ret < 0)
ERROR_RETURN("Could not set I-frame interval");
ret = ctx->m_VideoEncoder->setFrameRate(30, 1);
if (ret < 0)
ERROR_RETURN("Could not set m_VideoEncoderoder framerate");
// Query, Export and Map the output plane buffers so that we can read
// raw data into the buffers
ret = ctx->m_VideoEncoder->output_plane.setupPlane(V4L2_MEMORY_DMABUF, 10, false, false);
if (ret < 0)
ERROR_RETURN("Could not setup output plane");
// Query, Export and Map the output plane buffers so that we can write
// m_VideoEncoderoded data from the buffers
ret = ctx->m_VideoEncoder->capture_plane.setupPlane(V4L2_MEMORY_MMAP, 10, true, false);
if (ret < 0)
ERROR_RETURN("Could not setup capture plane");
printf("create video encoder return true\n");
return true;
static bool init_components(context_t * ctx)
/*Initialize Camera*/
if (!camera_initialize(ctx))
ERROR_RETURN("Failed to initialize camera device");
/*Create Video Encoder*/
if (!createVideoEncoder(ctx))
ERROR_RETURN("Failed to initialize encoder");
/*Create an output file*/
ctx->m_outputFile = new std::ofstream(ctx->cam_file);
printf("Initialize v4l2 componenets successfully\n");
INFO("Initialize v4l2 components successfully");
return true;
static bool request_camera_buff(context_t *ctx)
// Request camera v4l2 buffer
struct v4l2_requestbuffers rb;
memset(&rb, 0, sizeof(rb));
rb.count = V4L2_BUFFERS_NUM;
rb.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
rb.memory = V4L2_MEMORY_DMABUF;
if (ioctl(ctx->cam_fd, VIDIOC_REQBUFS, &rb) < 0)
ERROR_RETURN("Failed to request v4l2 buffers: %s (%d)",
if (rb.count != V4L2_BUFFERS_NUM)
ERROR_RETURN("V4l2 buffer number is not as desired");
for (unsigned int index = 0; index < V4L2_BUFFERS_NUM; index++)
struct v4l2_buffer buf;
// Query camera v4l2 buf length
memset(&buf, 0, sizeof buf);
buf.index = index;
buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
buf.memory = V4L2_MEMORY_DMABUF;
if (ioctl(ctx->cam_fd, VIDIOC_QUERYBUF, &buf) < 0)
ERROR_RETURN("Failed to query buff: %s (%d)",
// TODO add support for multi-planer
// Enqueue empty v4l2 buff into camera capture plane
buf.m.fd = (unsigned long)ctx->g_buff[index].dmabuff_fd;
if (buf.length != ctx->g_buff[index].size)
WARN("Camera v4l2 buf length is not expected");
ctx->g_buff[index].size = buf.length;
if (ioctl(ctx->cam_fd, VIDIOC_QBUF, &buf) < 0)
ERROR_RETURN("Failed to enqueue buffers: %s (%d)",
return true;
static bool prepare_buffers(context_t * ctx)
// Allocate global buffer context
ctx->g_buff = (nv_buffer *)malloc(V4L2_BUFFERS_NUM * sizeof(nv_buffer));
if (ctx->g_buff == NULL)
ERROR_RETURN("Failed to allocate global buffer context");
// Create buffer and share it with camera and VIC output plane
int fd;
NvBufferParams params = {0};
if (-1 == NvBufferCreate(&fd, ctx->cam_w, ctx->cam_h,
NvBufferLayout_Pitch,
get_nvbuff_color_fmt(ctx->cam_pixfmt)))
ERROR_RETURN("Failed to create NvBuffer");
ctx->g_buff[index].dmabuff_fd = fd;
if (-1 == NvBufferGetParams(fd, ¶ms))
ERROR_RETURN("Failed to get NvBuffer parameters");
// TODO add multi-planar support
// Currently it supports only YUV422 interlaced single-planar
ctx->g_buff[index].size = params.height[0] * params.pitch[0];
ctx->g_buff[index].start = (unsigned char *)mmap(
NULL,
ctx->g_buff[index].size,
PROT_READ | PROT_WRITE,
MAP_SHARED,
ctx->g_buff[index].dmabuff_fd, 0);
if (!request_camera_buff(ctx))
ERROR_RETURN("Failed to set up camera buff");
// Enqueue all the empty output plane buffers
for (uint32_t i = 0; i < ctx->m_VideoEncoder->output_plane.getNumBuffers(); i++)
struct v4l2_buffer v4l2_buf;
struct v4l2_plane planes[MAX_PLANES];
memset(&v4l2_buf, 0, sizeof(v4l2_buf));
memset(planes, 0, MAX_PLANES * sizeof(struct v4l2_plane));
v4l2_buf.index = i;
v4l2_buf.m.planes = planes;
if(ctx->m_VideoEncoder->output_plane.qBuffer(v4l2_buf, NULL) < 0) {
abort(ctx);
ERROR_RETURN("Failed to queue buffer on VIC capture plane");
// Enqueue all the empty capture plane buffers
for (uint32_t i = 0; i < ctx->m_VideoEncoder->capture_plane.getNumBuffers(); i++)
v4l2_buf.index = i;
if(ctx->m_VideoEncoder->capture_plane.qBuffer(v4l2_buf, NULL) < 0) {
abort(ctx);
INFO("Succeed in preparing stream buffers");
return true;
static bool start_stream(context_t * ctx)
enum v4l2_buf_type type;
int e;
// Start v4l2 streaming
if (ioctl(ctx->cam_fd, VIDIOC_STREAMON, &type) < 0)
ERROR_RETURN("Failed to start streaming: %s (%d)",
/*Stream on*/
e = ctx->m_VideoEncoder->output_plane.setStreamStatus(true);
if (e < 0)
ERROR_RETURN("Failed to stream on output plane");
e = ctx->m_VideoEncoder->capture_plane.setStreamStatus(true);
if (e < 0)
ERROR_RETURN("Failed to stream on capture plane");
usleep(200);
INFO("Camera video streaming on ...");
return true;
NvBuffer * buffer,
void *arg) {
context_t *ctx = (context_t *) arg;
nv_buffer * cam_g_buff;
printf("Output plane callback\n");
if (!v4l2_buf)
abort(ctx);
ERROR_RETURN("Failed to dequeue conv output plane buffer");
// Fetch nv_buffer to do format conversion
pthread_mutex_lock(&ctx->queue_lock);
while (ctx->enc_output_plane_buf_queue->empty())
pthread_cond_wait(&ctx->queue_cond, &ctx->queue_lock);
cam_g_buff = ctx->enc_output_plane_buf_queue->front();
ctx->enc_output_plane_buf_queue->pop();
pthread_mutex_unlock(&ctx->queue_lock);
// Got EOS signal and return
if (cam_g_buff->dmabuff_fd == 0)
return false;
else
// Enqueue enc output plane
v4l2_buf->m.planes[0].m.fd =
(unsigned long)cam_g_buff->dmabuff_fd;
v4l2_buf->m.planes[0].bytesused = cam_g_buff->size;
if (ctx->m_VideoEncoder->output_plane.qBuffer(*v4l2_buf, NULL) < 0)
abort(ctx);
ERROR_RETURN("Failed to enqueue VIC output plane");
return true;
bool encoderCapturePlaneDqCallback(struct v4l2_buffer *v4l2_buf,
NvBuffer * buffer,
void *arg) {
printf("Capture plane callback\n");
context_t * ctx = (context_t*)arg;
if (!v4l2_buf) {
abort(ctx);
ERROR_RETURN("Failed to dequeue buffer from encoder capture plane");
ctx->m_outputFile->write((char*) buffer->planes[0].data, buffer->planes[0].bytesused);
if (ctx->m_VideoEncoder->capture_plane.qBuffer(*v4l2_buf, buffer) < 0) {
abort(ctx);
ERROR_RETURN("Error while Qing buffer at capture plane");
// GOT EOS from m_VideoEncoderoder. Stop dqthread.
if (buffer->planes[0].bytesused == 0)
ERROR_RETURN("Got EOS, exiting...\n");
return false;
return true;
ctx->got_error = true;
if (ctx->m_VideoEncoder)
ctx->m_VideoEncoder->abort();
static void signal_handle(int signum)
printf("Quit due to exit command from user!\n");
quit = true;
static bool start_capture(context_t * ctx)
struct sigaction sig_action;
struct pollfd fds[1];
int bufferIndex = 0;
// Ensure a clean shutdown if user types <ctrl+c>
sig_action.sa_handler = signal_handle;
sigemptyset(&sig_action.sa_mask);
sig_action.sa_flags = 0;
sigaction(SIGINT, &sig_action, NULL);
// Set video encoder callback
ctx->m_VideoEncoder->capture_plane.setDQThreadCallback(encoderCapturePlaneDqCallback);
ctx->m_VideoEncoder->output_plane.setDQThreadCallback(encoderOutputPlaneDqCallback);
// startDQThread starts a thread internally which calls the
// encoderCapturePlaneDqCallback whenever a buffer is dequeued
// on the plane
ctx->m_VideoEncoder->capture_plane.startDQThread(ctx);
ctx->m_VideoEncoder->output_plane.startDQThread(ctx);
fds[0].fd = ctx->cam_fd;
fds[0].events = POLLIN;
while (poll(fds, 1, 5000) > 0 && !ctx->got_error && !quit)
if (fds[0].revents & POLLIN) {
// Dequeue camera buff
v4l2_buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
v4l2_buf.memory = V4L2_MEMORY_DMABUF;
if (ioctl(ctx->cam_fd, VIDIOC_DQBUF, &v4l2_buf) < 0) {
ERROR_RETURN("Failed to dequeue camera buff: %s (%d)",
ctx->frame++;
// Push nv_buffer into conv output queue for conversion
ctx->enc_output_plane_buf_queue->push(&ctx->g_buff[v4l2_buf.index]);
//ctx->m_outputFile->write((char*) ctx->g_buff[v4l2_buf.index].start, ctx->g_buff[v4l2_buf.index].size);
pthread_cond_broadcast(&ctx->queue_cond);
// Enqueue camera buff
// It might be more reasonable to wait for the completion of
// VIC processing before enqueue current buff. But VIC processing
// time is far less than camera frame interval, so we probably
// don't need such synchonization.
if (ioctl(ctx->cam_fd, VIDIOC_QBUF, &v4l2_buf))
ERROR_RETURN("Failed to queue camera buffers: %s (%d)",
if (quit)
// Signal EOS to the dq thread of VIC output plane
ctx->g_buff[0].dmabuff_fd = 0;
//TODO: ctx->conv_output_plane_buf_queue->push(&ctx->g_buff[0]);
// Stop Encoder thread
if (!ctx->got_error)
ctx->m_VideoEncoder->waitForIdle(2000);
ctx->m_VideoEncoder->capture_plane.stopDQThread();
ctx->m_VideoEncoder->output_plane.stopDQThread();
return true;
static bool stop_stream(context_t * ctx)
// Stop v4l2 streaming
if (ioctl(ctx->cam_fd, VIDIOC_STREAMOFF, &type))
ERROR_RETURN("Failed to stop streaming: %s (%d)",
INFO("Camera video streaming off ...");
return true;
int main(int argc, char *argv[])
context_t ctx;
int error = 0;
set_defaults(&ctx);
CHECK_ERROR(parse_cmdline(&ctx, argc, argv), cleanup,
"Invalid options specified");
CHECK_ERROR(init_components(&ctx), cleanup,
"Failed to initialize v4l2 components");
CHECK_ERROR(prepare_buffers(&ctx), cleanup,
"Failed to prepare v4l2 buffs");
CHECK_ERROR(start_stream(&ctx), cleanup,
"Failed to start streaming");
CHECK_ERROR(start_capture(&ctx), cleanup,
"Failed to start capturing")
CHECK_ERROR(stop_stream(&ctx), cleanup,
"Failed to stop streaming");
cleanup:
if (ctx.cam_fd > 0)
close(ctx.cam_fd);
if (ctx.g_buff != NULL)
for (unsigned i = 0; i < V4L2_BUFFERS_NUM; i++)
if (ctx.g_buff[i].dmabuff_fd)
NvBufferDestroy(ctx.g_buff[i].dmabuff_fd);
free(ctx.g_buff);
if (error)
printf("App run failed\n");
else
printf("App run was successful\n");
return -error;
If I feed raw data to encoder directly as below it got segmentation fault
ctx->frame++;
//ctx->enc_output_plane_buf_queue->push(&ctx->g_buff[v4l2_buf.index]);
nv_buffer * cam_g_buff = (nv_buffer*) &ctx->g_buff[v4l2_buf.index];
v4l2_buf.m.planes[0].m.fd = (unsigned long)cam_g_buff->dmabuff_fd;
v4l2_buf.m.planes[0].bytesused = cam_g_buff->size;
if (ctx->m_VideoEncoder->output_plane.qBuffer(v4l2_buf, NULL) < 0) {
abort(ctx);
Thanks and Best Regards,
Vu Nguyen
