Hello NVIDIA community,
I am currently facing an issue with my NVIDIA Quadro K2200 GPU, which is not being detected by deep learning frameworks like TensorFlow and PyTorch on my PC. I’ve followed all the recommended steps for setting up my GPU, but it still doesn’t seem to work for my projects. Here’s a detailed overview of my setup and the steps I’ve taken:
System and Software Details:
- GPU: NVIDIA Quadro K2200
- Driver Version: 31.0.15.5222
- CUDA Version: 10.2 (nvcc shows release 10.2, V10.2.89)
- OS: Windows 10, 64-bit
- Deep Learning Frameworks:
- TensorFlow 2.4.0 (installed with pip)
- PyTorch with CUDA Toolkit 10.2 (installed via Conda)
Steps I Have Already Tried:
- Installed Latest NVIDIA Drivers:
- Verified my driver version matches the compatibility with CUDA 10.2.
- Checked the GPU in Device Manager, and it is listed under Display Adapters.
- Installed CUDA Toolkit 10.2:
- Confirmed installation using
nvcc --version.
- Installed cuDNN:
- Downloaded the appropriate cuDNN version for CUDA 10.2.
- Environment Setup:
- Created a new environment in Miniconda specifically for deep learning projects.
- Installed TensorFlow 2.4.0 and PyTorch (with
cudatoolkit=10.2).
- Troubleshooting GPU Usage:
- Checked GPU availability in TensorFlow using:
python
Copy code
import tensorflow as tf
print("Num GPUs Available:", len(tf.config.list_physical_devices('GPU')))
Result: Num GPUs Available: 0
- Checked GPU availability in PyTorch using:
python
Copy code
import torch
print("Is CUDA available:", torch.cuda.is_available())
Result: Is CUDA available: False
6. Verified GPU Status with nvidia-smi:
- Ran
nvidia-smi, and it successfully displayed the GPU’s information and utilization.
- Closed Conflicting Processes:
- Ensured no other processes were using the GPU (verified via Task Manager and
nvidia-smi).
Current Issue:
Despite following all the steps mentioned above, my deep learning frameworks are still unable to detect the GPU. Both TensorFlow and PyTorch report that no GPU is available, even though the system recognizes the GPU (confirmed through Device Manager and nvidia-smi).
Questions for the Community:
- Are there any additional steps I should try to resolve this issue?
- Could this be a compatibility problem with the Quadro K2200 and modern frameworks like TensorFlow or PyTorch?
- Are there specific versions of TensorFlow or PyTorch that work better with CUDA 10.2 and the Quadro K2200?
Any help or suggestions would be greatly appreciated! Thank you in advance for your time and support.
