NVIDIA SDK - Flashing Jetson AGX Xavier
I pressed the “Power On”-Button only and recorded the log using Minicom.
And after running recovery mode and flash, it will go to this one and cannot flash?
0084.175] E> FAILED: MEMIO rail config
[0084.189] E> Task 50 failed (err: 0x7979061c)
[0084.193] E> Top caller module: ALIASCHECKER, error module: ALIASCHECKER, reas6
[0084.202] I> MB1(1.5.1.9-t194-41334769-73a9b7ef) BIT boot status dump :
00000000000111111111100001111111111111100110001111100000000000000000000000000000
[0084.232] I> Reset to recovery mode
When going into Recovery-Mode manually (pressing Middle & Power Button) and flashing using SDK in Manual mode, the last couple lines in the Minicom-Log before the SDK throws errors are those, yes.
See NVIDIA SDK - Flashing Jetson AGX Xavier - #17 by schoeneberg
Are you sure this is not AGX industrial module but a AGX xavier module?
Sorry, was on vacation. Yes, I am certain.
Please try with JetPack 5.0.2 GA release.
If still an issue, please help to open a new topic.
we organized another Jetson AGX, used the same methods and it worked. Since this is the case, it appears the board from the question “simply” has hardware issues. Whatever they might be.
Greetings
Eric
