When running
nvidia-settings --verbose -a "GPUMemoryTransferRateOffsetAllPerformanceLevels=1270"
the command has no effect and I’m getting the following warning:
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:0].
See attached files for system configuration and log files.
Thank you in advance for your help.
Output from nvidia-settings:
WARNING: NV-CONTROL extension not present on screen 0 of this Display.
WARNING: Unable to determine number of NVIDIA Frame Lock Devices on ':0'.
WARNING: Unable to determine number of NVIDIA 3D Vision Pro Transceivers on ':0'.
WARNING: Unable to determine number of NVIDIA Display Devices on ':0'.
WARNING: Unable to determine number of NVIDIA X Screens on ':0'.
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:1].
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:2].
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:3].
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:4].
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:5].
WARNING: Attribute 'GPUMemoryTransferRateOffsetAllPerformanceLevels' specified in assignment 'GPUMemoryTransferRateOffsetAllPerformanceLevels=1270' is not available on hostx:0[gpu:6].
Output from nvidia-smi:
Tue Jan 26 00:22:11 2021
| NVIDIA-SMI 460.32.03 Driver Version: 460.32.03 CUDA Version: 11.2 |
| | | MIG M. |
| 0 GeForce GTX 1070 Off | 00000000:01:00.0 Off | N/A |
| 0% 24C P8 5W / 151W | 6MiB / 8119MiB | 0% Default |
| | | N/A |
| 1 GeForce GTX 1070 Off | 00000000:02:00.0 Off | N/A |
| 0% 28C P8 7W / 180W | 6MiB / 8119MiB | 0% Default |
| | | N/A |
| 2 GeForce GTX 1070 Off | 00000000:03:00.0 Off | N/A |
| 0% 29C P8 7W / 180W | 6MiB / 8119MiB | 0% Default |
| | | N/A |
| 3 GeForce GTX 1070 Off | 00000000:06:00.0 Off | N/A |
| 0% 27C P8 4W / 151W | 6MiB / 8119MiB | 0% Default |
| | | N/A |
| 4 GeForce GTX 1070 Off | 00000000:07:00.0 Off | N/A |
| 0% 20C P8 4W / 151W | 6MiB / 8119MiB | 0% Default |
| | | N/A |
| 5 GeForce GTX 1070 Off | 00000000:09:00.0 Off | N/A |
| 0% 31C P8 7W / 180W | 6MiB / 8119MiB | 0% Default |
| | | N/A |
| 6 GeForce GTX 1070 Off | 00000000:0A:00.0 Off | N/A |
| 0% 29C P8 4W / 151W | 6MiB / 8119MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1042 G /usr/libexec/Xorg 4MiB |
| 1 N/A N/A 1042 G /usr/libexec/Xorg 4MiB |
| 2 N/A N/A 1042 G /usr/libexec/Xorg 4MiB |
| 3 N/A N/A 1042 G /usr/libexec/Xorg 4MiB |
| 4 N/A N/A 1042 G /usr/libexec/Xorg 4MiB |
| 5 N/A N/A 1042 G /usr/libexec/Xorg 4MiB |
| 6 N/A N/A 1042 G /usr/libexec/Xorg 4MiB |
Output of lspci
00:00.0 Host bridge: Intel Corporation 8th Gen Core 4-core Desktop Processor Host Bridge/DRAM Registers [Coffee Lake S] (rev 08)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 08)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 630
00:14.0 USB controller: Intel Corporation 200 Series/Z370 Chipset Family USB 3.0 xHCI Controller
00:16.0 Communication controller: Intel Corporation 200 Series PCH CSME HECI #1
00:17.0 SATA controller: Intel Corporation 200 Series PCH SATA controller [AHCI mode]
00:1b.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #17 (rev f0)
00:1b.4 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #21 (rev f0)
00:1c.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #1 (rev f0)
00:1c.3 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #4 (rev f0)
00:1c.4 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #5 (rev f0)
00:1c.5 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #6 (rev f0)
00:1c.6 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #7 (rev f0)
00:1c.7 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #8 (rev f0)
00:1d.0 PCI bridge: Intel Corporation 200 Series PCH PCI Express Root Port #9 (rev f0)
00:1f.0 ISA bridge: Intel Corporation Z370 Chipset LPC/eSPI Controller
00:1f.2 Memory controller: Intel Corporation 200 Series/Z370 Chipset Family Power Management Controller
00:1f.3 Audio device: Intel Corporation 200 Series PCH HD Audio
00:1f.4 SMBus: Intel Corporation 200 Series/Z370 Chipset Family SMBus Controller
01:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
02:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
02:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
03:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
03:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
06:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
06:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
07:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
07:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
09:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
09:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
0a:00.0 VGA compatible controller: NVIDIA Corporation GP104 [GeForce GTX 1070] (rev a1)
0a:00.1 Audio device: NVIDIA Corporation GP104 High Definition Audio Controller (rev a1)
Installed packages:
Installed Packages
akmod-nvidia.x86_64 3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
kmod-nvidia-5.10.7-200.fc33.x86_64.x86_64 3:460.32.03-1.fc33 @@commandline
kmod-nvidia-5.10.9-201.fc33.x86_64.x86_64 3:460.32.03-1.fc33 @@commandline
kmod-nvidia-5.9.16-200.fc33.x86_64.x86_64 3:460.32.03-1.fc33 @@commandline
nvidia-persistenced.x86_64 3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
nvidia-settings.x86_64 3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
nvidia-xconfig.x86_64 3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia.x86_64 3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-cuda.x86_64 3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-cuda-libs.x86_64 3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-devel.x86_64 3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-kmodsrc.x86_64 3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
xorg-x11-drv-nvidia-libs.x86_64 3:460.32.03-1.fc33 @rpmfusion-nonfree-updates
boot.log (218.1 KB)
xorg.conf (2.0 KB)
Xorg.0.log (175.7 KB)
