hi there! apart from this being a possible duplicate of another issue that happened in mid 2019, after running nvidia-settings with sudo and with being logged in as root, it’s unable to save just my display configuration. nvidia-settings output after running it in xfce4-terminal
op17@owen-xubuntu:~$ sudo nvidia-settings
[sudo] password for op17:
(nvidia-settings:30998): GLib-GObject-CRITICAL **: 08:25:12.136: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** Message: 08:25:12.401: PRIME: No offloading required. Abort
** Message: 08:25:12.401: PRIME: is it supported? no
Package xorg-server was not found in the pkg-config search path.
Perhaps you should add the directory containing 'xorg-server.pc'
to the PKG_CONFIG_PATH environment variable
No package 'xorg-server' found
my system output using neofetch
op17@owen-xubuntu:~$ neofetch
.-/+oossssoo+/-. op17@owen-xubuntu
`:+ssssssssssssssssss+:` -----------------
-+ssssssssssssssssssyyssss+- OS: Ubuntu 20.04.4 LTS x86_64
.ossssssssssssssssssdMMMNysssso. Kernel: 5.13.0-35-generic
/ssssssssssshdmmNNmmyNMMMMhssssss/ Uptime: 12 hours, 6 mins
+ssssssssshmydMMMMMMMNddddyssssssss+ Packages: 1888 (dpkg) /sssssssshNMMMyhhyyyyhmNMMMNhssssssss/ Shell: bash 5.0.17 .ssssssssdMMMNhsssssssssshNMMMdssssssss. Resolution: 1024x768, 1920x1080 +sssshhhyNMMNyssssssssssssyNMMMysssssss+ DE: Xfce
ossyNMMMNyMMhsssssssssssssshmmmhssssssso WM: Xfwm4
ossyNMMMNyMMhsssssssssssssshmmmhssssssso WM Theme: Greybird-dark
+sssshhhyNMMNyssssssssssssyNMMMysssssss+ Theme: Greybird-dark [GTK2], Greybird [GTK3]
.ssssssssdMMMNhsssssssssshNMMMdssssssss. Icons: Papirus-Dark [GTK2], elementary-xfce-darker [GTK3]
/sssssssshNMMMyhhyyyyhdNMMMNhssssssss/ Terminal: xfce4-terminal
+sssssssssdmydMMMMMMMMddddyssssssss+ Terminal Font: Monospace 10
/ssssssssssshdmNNNNmyNMMMMhssssss/ CPU: Intel i3-2100 (4) @ 3.100GHz
.ossssssssssssssssssdMMMNysssso. GPU: NVIDIA GeForce GT 710
-+sssssssssssssssssyyyssss+- Memory: 1990MiB / 15967MiB
.-/+oossssoo+/-.
ignoring the crooked ubuntu logo, this is a fresh install of xubuntu 20.04.3 LTS of where I spent most of it trying to combat mouse sensitivity, firefox blinding me with its light theme everytime I launch it and the wierd inability to save my display config with nvidia-settings. comment or contact me if more information/logs/console outputs are needed. thanks in advance!
