I have already installed the nvidia-driver-410 via ppa. The nvidia-smi can show the information of the GPU.
But the nvidia-settings does not work. It shows that.
ERROR: Unable to load info from any available system
And I use the command nvdia-xconfig. It shows that.
good@AirSim:~$ sudo nvidia-xconfig
[sudo] password for good:
WARNING: Unable to locate/open X configuration file.
Package xorg-server was not found in the pkg-config search path.
Perhaps you should add the directory containing `xorg-server.pc'
to the PKG_CONFIG_PATH environment variable
No package 'xorg-server' found
New X configuration file written to '/etc/X11/xorg.conf'
I have changed xorg.conf like above and reboot. However, after I type the password, the Ubuntu login interface get stuck.
Here is my bug report. http://paste.ubuntu.com/p/KtjkSrTnPB/
