Hi there,
I am using HP Omen with I7 running with GEForce RTX-3060.
I have installed nvidia/510.60.02 and here is
[pradeep@192 ~]$ dkms status
nvidia/510.60.02, 4.18.0-348.20.1.el8_5.x86_64, x86_64: installed
however nvidia-settings - shows below errors:
ERROR: NVIDIA driver is not loaded
(nvidia-settings:3968): GLib-GObject-CRITICAL **: 00:59:57.148: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nvidia-settings:3968): CRITICAL **: 00:59:57.149: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
I am attaching bug report - alongwith
- I have tried running laptop with disabling secure mode → but it stuck at start up with logo.
- I even tried putting ‘AllowEmptyInitialConfiguration’ in xorg.conf
- also prime-select command is not found
- and nvidia-rmi says
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
even though I downloaded it after searching the correct driver version. - My driver installation was successful.
nvidia-bug-report.log.gz (89.3 KB)
I have been trying this since past many weeks but seeing no success, any help will be deeply appreciated.
