I am running Kernel 3.10.0-957.27.2.el7.x86_64 on CentOS 7.6.1810, installed NVIDIA-Linux-x86_64-430.40
to be able to use NVIDIA GM107M [GeForce GTX 860M].
Installation went smoothly until I wanted to configure it. when I run
[root@y5070 ~]# nvidia-settings -V -c :0
WARNING: NV-CONTROL extension not found on this Display.
ERROR: Unable to load info from any available system
according to nvidia-smi it’s all good
[root@y5070 ~]# nvidia-smi
Fri Aug 16 01:40:18 2019
| NVIDIA-SMI 430.40 Driver Version: 430.40 CUDA Version: 10.1 |
| 0 GeForce GTX 860M Off | 00000000:01:00.0 Off | N/A |
| N/A 42C P8 N/A / N/A | 0MiB / 4046MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
The configuration for gdm.service is what I think I need to be generated as I can see the graphics but nvidia is not being used I don’t think.
I also tried using nvidia-xconfig but no luck, I had to delete the file generated because it won’t start gdm.service
nouveau is not loaded and nvidia is
[root@y5070 ~]# lsmod | egrep -i "nvidia|nouveau"
nvidia_uvm 814934 0
nvidia_drm 43690 0
nvidia_modeset 1112541 1 nvidia_drm
nvidia 19032409 23 nvidia_modeset,nvidia_uvm
ipmi_msghandler 56032 2 ipmi_devintf,nvidia
drm_kms_helper 179394 2 i915,nvidia_drm
drm 429744 5 i915,drm_kms_helper,nvidia_drm
[root@y5070 ~]# lspci -v -s `lspci | awk '/VGA/{print $1}'`
00:02.0 VGA compatible controller: Intel Corporation 4th Gen Core Processor Integrated Graphics Controller (rev 06) (prog-if 00 [VGA controller])
Subsystem: Lenovo Device 3978
Flags: bus master, fast devsel, latency 0, IRQ 31
Memory at d1000000 (64-bit, non-prefetchable)
Memory at c0000000 (64-bit, prefetchable)
I/O ports at 6000
Expansion ROM at <unassigned> [disabled]
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Capabilities: [d0] Power Management version 2
Capabilities: [a4] PCI Advanced Features
Kernel driver in use: i915
Kernel modules: i915
[root@y5070 ~]# lspci -v -s `lspci | awk '/3D/{print $1}'`
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 860M] (rev a2)
Flags: bus master, fast devsel, latency 0, IRQ 35
Memory at d0000000 (32-bit, non-prefetchable)
Memory at a0000000 (64-bit, prefetchable)
Memory at b0000000 (64-bit, prefetchable)
I/O ports at 5000
[virtual] Expansion ROM at b2000000 [disabled]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] #19
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
I need to be able to run nvidia-settings for gdm.service to be able to pick up the config I would imagine.
nvidia-bug-report.log.gz (375 KB)
