I’ve installed the proprietary driver(video-nvidia) for my gtx 960m graphic card on manjaro(arch base) linux using
$ sudo mhwd -auto pci nonfree 0300
command.
In the booting screen under the /dev/nvme0n1p3: clean, .... blocks
message, it says [FAILED] Failed to start Load Kernel Modules
in a moment and the system boots up.
$ nvidia-settings
ERROR: NVIDIA driver is not loaded
(nvidia-settings:3503): GLib-GObject-CRITICAL **: 14:19:17.629: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
** (nvidia-settings:3503): CRITICAL **: 14:19:17.631: ctk_powermode_new: assertion '(ctrl_target != NULL) && (ctrl_target->h != NULL)' failed
$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
I also had nvidia-settings could not find the registry key file or the X server is not accessible
error and fixed it by following this thread: [HowTo] Fix the ERROR: nvidia-settings could not find the registry key file or the X server is not accessible - Tutorials - Manjaro Linux Forum
here is the result of sudo nvidia-bug-report.sh
nvidia-bug-report.log.gz (113.8 KB)
and here are some other information that you might need based on this thread: Nvidia-settings incomplete on optimus laptop
$ xrandr --listproviders
Providers: number : 1
Provider 0: id: 0x43 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 2 associated providers: 0 name:modesetting
$ __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo | grep vendor
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 50
Current serial number in output stream: 51
