I have downloaded Nvidia drivers on my ThinkPad P1 Gen 2 laptop with Fedora 33 using this tutorial. Now my nvidia-settings behaves very weird. I really want to use the nvidia PRIME feature since I have a laptop with integrated and discrete graphics. I am using X11.
This is how the GUI looks:
This is the error that it shows when running it from the terminal (it also shows above GUI):
➜ ~ nvidia-settings
(nvidia-settings:21181): GLib-GObject-CRITICAL **: 21:02:25.552: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
** (nvidia-settings:21181): CRITICAL **: 21:02:25.554: ctk_powermode_new: assertion ‘(ctrl_target != NULL) && (ctrl_target->h != NULL)’ failed
Some info that you might need:
➜ ~ modinfo nvidia
filename: /lib/modules/5.10.13-200.fc33.x86_64/extra/nvidia/nvidia.ko
alias: char-major-195-*
version: 460.39
supported: external
license: NVIDIA
srcversion: 88778FD9C7BD9CA16708044
alias: pci:v000010DEdsvsdbc03sc02i00
alias: pci:v000010DEdsvsdbc03sc00i00
depends:
retpoline: Y
vermagic: 5.10.13-200.fc33.x86_64 SMP mod_unload
parm: NvSwitchRegDwords:NvSwitch regkey (charp)
parm: NvSwitchBlacklist:NvSwitchBlacklist=uuid[,uuid…] (charp)
parm: nv_cap_enable_devfs:Enable (1) or disable (0) nv-caps devfs support. Default: 1 (int)
parm: NVreg_ResmanDebugLevel:int
parm: NVreg_RmLogonRC:int
parm: NVreg_ModifyDeviceFiles:int
parm: NVreg_DeviceFileUID:int
parm: NVreg_DeviceFileGID:int
parm: NVreg_DeviceFileMode:int
parm: NVreg_InitializeSystemMemoryAllocations:int
parm: NVreg_UsePageAttributeTable:int
parm: NVreg_RegisterForACPIEvents:int
parm: NVreg_EnablePCIeGen3:int
parm: NVreg_EnableMSI:int
parm: NVreg_TCEBypassMode:int
parm: NVreg_EnableStreamMemOPs:int
parm: NVreg_EnableBacklightHandler:int
parm: NVreg_RestrictProfilingToAdminUsers:int
parm: NVreg_PreserveVideoMemoryAllocations:int
parm: NVreg_EnableS0ixPowerManagement:int
parm: NVreg_S0ixPowerManagementVideoMemoryThreshold:int
parm: NVreg_DynamicPowerManagement:int
parm: NVreg_DynamicPowerManagementVideoMemoryThreshold:int
parm: NVreg_EnableUserNUMAManagement:int
parm: NVreg_MemoryPoolSize:int
parm: NVreg_KMallocHeapMaxSize:int
parm: NVreg_VMallocHeapMaxSize:int
parm: NVreg_IgnoreMMIOCheck:int
parm: NVreg_NvLinkDisable:int
parm: NVreg_EnablePCIERelaxedOrderingMode:int
parm: NVreg_RegisterPCIDriver:int
parm: NVreg_RegistryDwords:charp
parm: NVreg_RegistryDwordsPerDevice:charp
parm: NVreg_RmMsg:charp
parm: NVreg_GpuBlacklist:charp
parm: NVreg_TemporaryFilePath:charp
➜ ~ lspci -vnnn | grep VGA
00:02.0 VGA compatible controller [0300]: Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630] [8086:3e9b] (prog-if 00 [VGA controller])
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU117GLM [Quadro T1000 Mobile] [10de:1fb9] (rev a1) (prog-if 00 [VGA controller])
➜ ~ dnf list installed | grep nvidia
akmod-nvidia.x86_64 3:460.39-1.fc33 @rpmfusion-nonfree-nvidia-driver
kmod-nvidia-5.10.10-200.fc33.x86_64.x86_64 3:460.39-1.fc33 @@commandline
kmod-nvidia-5.10.11-200.fc33.x86_64.x86_64 3:460.39-1.fc33 @@commandline
kmod-nvidia-5.10.13-200.fc33.x86_64.x86_64 3:460.39-1.fc33 @@commandline
nvidia-settings.x86_64 3:460.39-1.fc33 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia.x86_64 3:460.39-1.fc33 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia-kmodsrc.x86_64 3:460.39-1.fc33 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia-libs.i686 3:460.39-1.fc33 @rpmfusion-nonfree-nvidia-driver
xorg-x11-drv-nvidia-libs.x86_64 3:460.39-1.fc33 @rpmfusion-nonfree-nvidia-driver
