Trying glxinfo using Intel:
$ glxinfo | grep vendor
server glx vendor string: SGI
client glx vendor string: Mesa Project and SGI
OpenGL vendor string: Intel Open Source Technology Center
Then trying glxinfo using PRIME offloading and getting an error:
$ __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo | grep vendor
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 39
Current serial number in output stream: 40
$ lsmod | grep nvidia
nvidia_uvm 954368 0
nvidia_drm 45056 2
nvidia_modeset 1114112 1 nvidia_drm
nvidia 20402176 2 nvidia_uvm,nvidia_modeset
drm_kms_helper 184320 2 nvidia_drm,i915
drm 487424 16 drm_kms_helper,nvidia_drm,i915
ipmi_msghandler 106496 2 ipmi_devintf,nvidia
$ nvidia-smi
Mon Feb 3 02:40:46 2020
| NVIDIA-SMI 440.44 Driver Version: 440.44 CUDA Version: 10.2 |
| 0 GeForce MX150 Off | 00000000:02:00.0 Off | N/A |
| N/A 40C P8 N/A / N/A | 0MiB / 2002MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
$ ls -l /etc/X11/
total 84
-rwxr-xr-x 1 root root 709 Jan 20 2017 Xreset
drwxr-xr-x 2 root root 4096 Jan 10 21:10 Xreset.d
drwxr-xr-x 2 root root 4096 Jan 10 21:10 Xresources
-rwxr-xr-x 1 root root 3730 Dec 14 2018 Xsession
drwxr-xr-x 2 root root 4096 Feb 2 00:32 Xsession.d
-rw-r--r-- 1 root root 265 Jan 20 2017 Xsession.options
-rw-r--r-- 1 root root 13 Dec 5 2016 XvMCConfig
-rw-r--r-- 1 root root 630 Apr 16 2019 Xwrapper.config
drwxr-xr-x 2 root root 4096 Nov 30 01:49 app-defaults
drwxr-xr-x 2 root root 4096 Oct 8 21:48 cursors
-rw-r--r-- 1 root root 15 Oct 8 21:41 default-display-manager
drwxr-xr-x 4 root root 4096 Apr 16 2019 fonts
-rw-r--r-- 1 root root 17394 Jan 20 2017 rgb.txt
drwxr-xr-x 2 root root 4096 Oct 8 21:48 xinit
drwxr-xr-x 2 root root 4096 Oct 25 2018 xkb
-rw-r--r-- 1 root root 448 Feb 3 02:49 xorg.conf
drwxr-xr-x 2 root root 4096 Apr 16 2019 xsm
$ cat /etc/X11/xorg.conf
Section "Files"
ModulePath "/usr/lib/xorg/modules"
ModulePath "/usr/lib/nvidia/xorg"
EndSection
Section "ServerLayout"
Identifier "layout"
Screen 0 "iGPU"
Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
Identifier "iGPU"
Driver "modesetting"
BusID "PCI:0:2:0"
EndSection
Section "Screen"
Identifier "iGPU"
Device "iGPU"
EndSection
Section "Device"
Identifier "nvidia"
Driver "nvidia"
BusID "PCI:1:0:0"
EndSection
$ ls -l /usr/share/X11/xorg.conf.d/
total 28
-rw-r--r-- 1 root root 190 Feb 3 02:07 10-nvidia.conf
-rw-r--r-- 1 root root 1350 Jan 14 16:43 10-quirks.conf
-rw-r--r-- 1 root root 149 Feb 3 02:19 11-nvidia-offload.conf
-rw-r--r-- 1 root root 1429 Aug 13 14:13 40-libinput.conf
-rw-r--r-- 1 root root 590 Aug 24 2018 51-synaptics-quirks.conf
-rw-r--r-- 1 root root 1751 Aug 24 2018 70-synaptics.conf
-rw-r--r-- 1 root root 3458 Nov 21 19:13 70-wacom.conf
$ cat /usr/share/X11/xorg.conf.d/10-nvidia.conf
Section "OutputClass"
Identifier "nvidia"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
ModulePath "/usr/lib/x86_64-linux-gnu/nvidia/xorg"
EndSection
$ cat /usr/share/X11/xorg.conf.d/11-nvidia-offload.conf
# DO NOT EDIT. AUTOMATICALLY GENERATED BY gpu-manager
Identifier "layout"
EndSection
Files .local/share/xorg/Xorg.1.log and nvidia-bug-report.log.gz are in the attachment.
nvidia-bug-report.log.gz (283 KB)
Xorg.1.log (50.4 KB)
