I’m running arch linux 5.10, on a laptop with a dedicated GTX 1050 graphics card. I followed the nvidia prime archwiki page.
I am facing the following problem:
When running glxinfo with nvidia gpu:
prime-run glxinfo
I get the following error:
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 3 (X_GLXCreateContext)
Value in failed request: 0x0
Serial number of failed request: 25
Current serial number in output stream: 26
It seems that the nvidia driver loads according to “lspci -nnk”.
I have searched for simliar cases and I found the following topic:
I followed the solution given to him but it made no change.
I did the following changes to fix the problem:
Added nvidia-drm.modeset=1 kernel parameter.
Added modules nvidia nvidia_modeset nvidia_uvm nvidia_drm to /etc/mkinitcpio.conf and ran mkinitcpio -p linux.
Here is my xorg.conf (after following the linked topic:
