OK. So i have set everything up as per the arch wiki and the nvidia docs Chapter 33. Offloading Graphics Display with RandR 1.4 and if i execute:
nvidia-bug-report.log.gz.log (297.2 KB)
$ sudo xrandr --setprovideroutputsource modesetting NVIDIA-0
Could not find provider with name NVIDIA-0
glxinfo | grep vendor
I get
server glx vendor string: SGI
client glx vendor string: Mesa Project and SGI
OpenGL vendor string: Intel Open Source Technology Center
This is the expected response. However if i try prime offloading using
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo | grep vendor
I get
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 39
Current serial number in output stream: 40
Also the output from nvidia-smi is
Sat Apr 4 18:25:34 2020
| NVIDIA-SMI 440.64 Driver Version: 440.64 CUDA Version: 10.2 |
| 0 GeForce GTX 1650 Off | 00000000:01:00.0 Off | N/A |
| N/A 50C P0 5W / N/A | 0MiB / 3914MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| No running processes found |
