I use HP Pavilion Gaming laptop with hybrin graphics.
If I’m trying to run this command:
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo | egrep "OpenGL vendor|OpenGL renderer"
I’m getting this error:
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 39
Current serial number in output stream: 40
And if I try to run any other game/program by using the Prime offload to run it on my NVIDIA GPU, the game/program runs on my integrated graphics.
nvidia-bug-report.log.gz (1.5 MB)
Can you please check xrandr --listproviders? From your bug report log, I see an Xorg.0.log.old where it loaded the NVIDIA driver correctly but in Xorg.0.log it didn’t, I think because the NVIDIA kernel modules (nvidia, nvidia-modeset, and nvidia-drm) aren’t loaded. It looks like the modules were loaded at one point, so I’m not sure why they are unloaded now.
xrandr --listproviders:
Providers: number : 1
Provider 0: id: 0x54; cap: 0xf (Source Output, Sink Output, Source Offload, Sink Offload); crtcs: 4; outputs: 1; associated providers: 0; name: Unknown AMD Radeon GPU @ pci:0000:05:00.0
output eDP
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia xrandr --listproviders:
output eDP
lsmod | grep nvidia:
nvidia_drm 65536 0
nvidia_modeset 1232896 1 nvidia_drm
nvidia_uvm 1146880 0
nvidia 34197504 2 nvidia_uvm,nvidia_modeset
drm_kms_helper 286720 2 amdgpu,nvidia_drm
drm 573440 18 gpu_sched,drm_kms_helper,amdgpu,drm_ttm_helper,nvidia_drm,ttm
cat /etc/dracut.conf.d/60-nvidia-default.conf:
add_drivers+=" nvidia nvidia-drm nvidia-modeset nvidia-uvm "
Please create /etc/X11/xorg.conf.d/10-nvidia.conf
Section "OutputClass"
Identifier "nvidia"
MatchDriver "nvidia-drm"
Driver "nvidia"
Option "AllowEmptyInitialConfiguration"
EndSection
