PRIME render offloading not working on my arch linux on a lenovo laptop with xfce+xorg
Running glx-info with prime-run (wraps all the needed environment variables) yields:
# prime-run glxinfo
name of display: :0.0
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  152 (GLX)
  Minor opcode of failed request:  24 (X_GLXCreateNewContext)
  Value in failed request:  0x0
  Serial number of failed request:  39
  Current serial number in output stream:  40
I have looked into https://devtalk.nvidia.com/default/topic/1068229/linux/problem-with-offloading-with-prime/ and i have tried:
  • removing /usr/share/X11/xorg.conf.d/10-nvidia-drm-outputclass.conf
  • Adding the Files section to 10-nvidia-drm-outputclass.conf (I don't have a /etc/X11/xorg.conf)
  • Adding nvidia-drm.modesetting=1 to the kernel cmdline via grub
— info dump —
Versions of things:
nvidia-dkms 440.44-5
linux-zen 5.4.6.zen1-1
xorg-server 1.20.6-2
lsmod | grep nv:
nvidia_drm             53248  1
nvidia_modeset       1118208  1 nvidia_drm
nvidia              20451328  1 nvidia_modeset
drm_kms_helper        229376  2 nvidia_drm,i915
drm                   573440  7 drm_kms_helper,nvidia_drm,i915
ipmi_msghandler        73728  2 ipmi_devintf,nvidia
I have not tested running on the stock linux kernel, but I doubt it will make a difference since zen simply changes the io scheduler, and my nvidia is installed with DKMS.
I tried adding nvidia-drm.modesetting=1 to the kernel cmdline which added Provider 1 in the output of xrandr --listproviders below, but it’s still not working.
Providers: number : 2
Provider 0: id: 0x46 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 4 associated providers: 0 name:modesetting
Provider 1: id: 0x22e cap: 0x0 crtcs: 0 outputs: 0 associated providers: 0 name:modesetting
I see no way to attach files in this form so i’ll upload them to Drive:
Output of glxinfo:
Output of __NV_PRIME_RENDER_OFFLOAD=1 __VK_LAYER_NV_optimus=NVIDIA_only __GLX_VENDOR_LIBRARY_NAME=nvidia glxinfo:
Output of nvidia-bug-report.sh:
If you want any more info, I’m here. Thanks in advance :)
nvidia-bug-report.log.gz (582 KB)
glxinfo_notworks.txt (330 Bytes)
glxinfo_works.txt (43 KB)
Please create /etc/X11/xorg.conf with contents
Section "ServerLayout"
  Identifier "layout"
  Screen 0 "iGPU"
  Option "AllowNVIDIAGPUScreens"
EndSection
Section "Device"
  Identifier "iGPU"
  Driver "modesetting"
  BusID "PCI:0:2:0"
EndSection
Section "Screen"
  Identifier "iGPU"
  Device "iGPU"
EndSection
Section "Device"
  Identifier "nvidia"
  Driver "nvidia"
  BusID "PCI:59:0:0"
EndSection
No dice, attaching updated nvidia-bug-report.log.gz.
nvidia-bug-report-new.log.gz (574 KB)
Please embed the nvidia modules in the initrd so thhey’re available at an earlier time on boot.
It worked! Thank you very much. Here’s my final config.
/usr/share/X11/xorg.conf.d/10-quirks.conf: (Probably arch linux specific)
# Collection of quirks and blacklist/whitelists for specific devices.
# Accelerometer device, posts data through ABS_X/ABS_Y, making X unusable
# http://bugs.freedesktop.org/show_bug.cgi?id=22442
Section "InputClass"
        Identifier "ThinkPad HDAPS accelerometer blacklist"
        MatchProduct "ThinkPad HDAPS accelerometer data"
        Option "Ignore" "on"
EndSection
# https://bugzilla.redhat.com/show_bug.cgi?id=523914
# Mouse does not move in PV Xen guest
# Explicitly tell evdev to not ignore the absolute axes.
        Identifier "Xen Virtual Pointer axis blacklist"
        MatchProduct "Xen Virtual Pointer"
        Option "IgnoreAbsoluteAxes" "off"
        Option "IgnoreRelativeAxes" "off"
EndSection
# https://bugs.freedesktop.org/show_bug.cgi?id=55867
# Bug 55867 - Doesn't know how to tag XI_TRACKBALL
        Identifier "Tag trackballs as XI_TRACKBALL"
        MatchProduct "trackball"
        MatchDriver "evdev"
        Option "TypeName" "TRACKBALL"
EndSection
# https://bugs.freedesktop.org/show_bug.cgi?id=62831
# Bug 62831 - Mionix Naos 5000 mouse detected incorrectly
        Identifier "Tag Mionix Naos 5000 mouse XI_MOUSE"
        MatchProduct "La-VIEW Technology Naos 5000 Mouse"
        MatchDriver "evdev"
        Option "TypeName" "MOUSE"
EndSection
/usr/share/X11/xorg.conf.d/40-libinput.conf: (Probably arch linux specific)
# Match on all types of devices but joysticks
# If you want to configure your devices, do not copy this file.
# Instead, use a config snippet that contains something like this:
# Section "InputClass"
#   Identifier "something or other"
#   MatchDriver "libinput"
#   MatchIsTouchpad "on"
#   ... other Match directives ...
#   Option "someoption" "value"
# EndSection
# This applies the option any libinput device also matched by the other
# directives. See the xorg.conf(5) man page for more info on
# matching devices.
        Identifier "libinput pointer catchall"
        MatchIsPointer "on"
        MatchDevicePath "/dev/input/event*"
        Driver "libinput"
EndSection
        Identifier "libinput keyboard catchall"
        MatchIsKeyboard "on"
        Driver "libinput"
EndSection
        Identifier "libinput touchpad catchall"
        Driver "libinput"
EndSection
        Identifier "libinput touchscreen catchall"
        MatchIsTouchscreen "on"
        Driver "libinput"
EndSection
        Identifier "libinput tablet catchall"
        MatchIsTablet "on"
        Driver "libinput"
EndSection
/etc/X11/xorg.conf:
Section "Files"
  ModulePath "/usr/lib/xorg/modules"
  ModulePath "/usr/lib/nvidia/xorg"
EndSection
  Identifier "layout"
  Screen 0 "iGPU"
EndSection
Section "Device"
  Identifier "iGPU"
  BusID "PCI:0:2:0"
EndSection
Section "Screen"
  Identifier "iGPU"
  Device "iGPU"
EndSection
Section "Device"
  Identifier "nvidia"
  Driver "nvidia"
  BusID "PCI:59:0:0"
EndSection
/etc/mkinitcpio.conf: (Probably arch linux specific)
MODULES=(nvidia nvidia_modeset nvidia_drm drm_kms_helper drm ipmi_msghandler)
Remember to run mkinitcpio -p linux (mkinitcpio -p linux-zen in my case)
There are no other (xorg config) files in either /usr/share/X11/xorg.conf.d/ or /etc/X11/xorg.conf.d/ except noted here.
Relevant packages that I have installed: mesa-demos nvidia-prime nvidia-settings dkms nvidia-dkms linux-zen-headers
Huge thanks to generix :)
