I installed nvidia driver 418 on my ubuntu 18.04.
- Running nvidia-smi gives this result:
| NVIDIA-SMI 418.56 Driver Version: 418.56 CUDA Version: 10.1 |
| 0 GeForce GTX 950M Off | 00000000:01:00.0 Off | N/A |
| N/A 46C P5 N/A / N/A | 135MiB / 2004MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1258 G /usr/lib/xorg/Xorg 76MiB |
| 0 1434 G /usr/bin/gnome-shell 57MiB |
- Running nvidia-settings allow me to open the Nviddia x server settings but at the same time this error appears:
(nvidia-settings:2490): GLib-GObject-CRITICAL **: 04:02:38.021: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
** Message: 04:02:38.728: PRIME: Requires offloading
** Message: 04:02:38.728: PRIME: is it supported? yes
- Added to that while running nvidia-xconfig this appears:
WARNING: Unable to locate/open X configuration file.
WARNING: Unable to parse X.Org version string.
Package xorg-server was not found in the pkg-config search path.
Perhaps you should add the directory containing `xorg-server.pc’
to the PKG_CONFIG_PATH environment variable
No package ‘xorg-server’ found
ERROR: Unable to write to directory ‘/etc/X11’.
- I also changed GRUB_CMDLINE_LINUX_DEFAULT value of /etc/default/grub to nouveau.modeset=0.
I need help.
nvidia-bug-report.log.gz (1.16 MB)
nvidia-bug-report.log (2.05 MB)
