I am using NVIDIA Tesla M10 GPU on vSphere and I failed to install open nvidia-settings after i installed driver
NVIDIA-Linux-x86_64-430.30-grid.run
nvidia-settings
WARNING: NV-CONTROL extension not found on this Display.
ERROR: Unable to load info from any available system
lspci
02:00.0 VGA compatible controller: NVIDIA Corporation GM107GL [Tesla M10] (rev a2) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation GRID M10-8Q
Physical Slot: 32
Flags: bus master, 66MHz, user-definable features, ?? devsel, latency 0, IRQ 64
Memory at fc000000 (32-bit, non-prefetchable)
Memory at d0000000 (64-bit, prefetchable)
Memory at fa000000 (64-bit, non-prefetchable)
I/O ports at 2000
Capabilities: <access denied>
Kernel driver in use: nvidia
Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
ps afx
752 tty1 Ss 0:00 /bin/login -p --
794 tty1 S 0:00 \_ -bash
804 tty1 S+ 0:00 \_ /bin/sh /usr/bin/startx
826 tty1 S+ 0:00 \_ xinit /etc/X11/xinit/xinitrc -- /etc/X11/xinit/xserverrc :0 vt1 -keeptty -auth /tmp/serverauth.wTZPxI0wNA
827 tty1 Sl 0:43 \_ /usr/lib/xorg/Xorg -nolisten tcp :0 vt1 -keeptty -auth /tmp/serverauth.wTZPxI0wNA
837 tty1 S 0:00 \_ /bin/sh /etc/xdg/xfce4/xinitrc -- /etc/X11/xinit/xserverrc
883 ? Ss 0:00 \_ /usr/bin/ssh-agent /usr/bin/im-launch x-session-manager
901 tty1 Sl 0:00 \_ xfce4-session
935 tty1 S 0:00 \_ xscreensaver -no-splash
936 tty1 Sl 0:00 \_ /usr/bin/python3 /usr/share/system-config-printer/applet.py
939 tty1 Sl 0:00 \_ /usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1
940 tty1 Sl 0:00 \_ nm-applet
nvidia-bug-report.log.gz (1.1 MB)
dmesg.log (73.3 KB)
xorg.log (24.9 KB)
vsphere
[root@medusa-02:~] nvidia-smi
Mon Jul 15 14:18:47 2019
| NVIDIA-SMI 430.27 Driver Version: 430.27 CUDA Version: N/A |
| 0 Tesla M10 On | 00000000:05:00.0 Off | N/A |
| N/A 34C P8 10W / 53W | 8141MiB / 8191MiB | 0% Default |
| 1 Tesla M10 On | 00000000:06:00.0 Off | N/A |
| N/A 32C P8 10W / 53W | 8141MiB / 8191MiB | 0% Default |
| 2 Tesla M10 On | 00000000:07:00.0 Off | N/A |
| N/A 28C P8 10W / 53W | 11MiB / 8191MiB | 0% Default |
| 3 Tesla M10 On | 00000000:08:00.0 Off | N/A |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1076491 C+G debian-tesla-m10 8128MiB |
| 1 1099169 C+G ubuntu-tesla-m10 8128MiB |
Virtual Device
test@ubuntu-tesla-m10:/etc$ cat lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION=“Ubuntu 18.04.2 LTS”
test@ubuntu-tesla-m10:~$ nvidia-smi
Mon Jul 15 10:15:26 2019
| NVIDIA-SMI 430.30 Driver Version: 430.30 CUDA Version: 10.2 |
| 0 GRID M10-8Q On | 00000000:02:00.0 Off | N/A |
| N/A N/A P8 N/A / N/A | 528MiB / 8192MiB | 0% Default |
| No running processes found |
The Xserver is currently running on the vmware adapter. Please try with this as xorg.conf:
Section "Device"
Identifier "nvidia"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:2:0:0"
Option "AllowEmptyInitialConfiguration"
EndSection
I did , but with startx i am stuck in cmd.
X.Org X Server 1.19.6
Release Date: 2017-12-20
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.4.0-148-generic x86_64 Ubuntu
Current Operating System: Linux ubuntu-tesla-m10 4.15.0-54-generic #58-Ubuntu SMP Mon Jun 24 10:55:24 UTC 2019 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.15.0-54-generic root=UUID=296b018d-6642-4753-bfbd-61ae8250d351 ro splash quiet
Build Date: 03 June 2019 08:10:35AM
xorg-server 2:1.19.6-1ubuntu4.3 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.34.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Jul 16 09:42:02 2019
(==) Using config file: "/etc/X11/xorg.conf"
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
xinit: connection to X server lost
waiting for X server to shut down (II) Server terminated successfully (0). Closing log file.
xinit: unexpected signal 15
xorg.log (17.5 KB)
There’s no client connecting to the Xserver, so it starts and just stops again. Create an ~/.xinitrc e.g. with contents
exec xterm
and the xserver will stay alive displaying an xterm.
753 tty1 Ss 0:00 /bin/login -p --
883 tty1 S 0:00 \_ -bash
1630 tty1 S+ 0:00 \_ /bin/sh /usr/bin/startx
1652 tty1 S+ 0:00 \_ xinit /home/test/.xinitrc -- /etc/X11/xinit/xserverrc :0 vt1 -keeptty -auth /tmp/serverauth.e1MQ9i3yrO
1653 tty1 Sl 9:43 \_ /usr/lib/xorg/Xorg -nolisten tcp :0 vt1 -keeptty -auth /tmp/serverauth.e1MQ9i3yrO
1661 tty1 Sl 0:00 \_ xfce4-session
1689 tty1 S 0:00 \_ xscreensaver -no-splash
1693 tty1 Sl 0:00 \_ /usr/bin/python3 /usr/share/system-config-printer/applet.py
1704 tty1 Sl 0:00 \_ /usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1
1705 tty1 Sl 0:00 \_ nm-applet
761 ? Ss 0:00 /lib/systemd/systemd --user
762 ? S 0:00 \_ (sd-pam)
938 ? SLs 0:00 \_ /usr/bin/gpg-agent --supervised
test@ubuntu-tesla-m10:~$ cat ~/.xinitrc
exec xfce4-session
I dont think that the case. Without this config its working.
BusID "PCI:2:0:0"
I guess its more xorg.conf configuration related,but i didnt figure it.
nvidia-bug-report.log.gz (1.07 MB)
According to the xorg logs, the Xserver is coming up correctly on the nvidia gpu.
Of course you can’t see it, the Tesla has no monitor outputs, or what is your issue? You can connect to it e.g. through x11vnc.
