(nvidia-settings:7150): GLib-GObject-CRITICAL **: 18:00:18.766: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
The issue I report looks common thing.
I run Ubuntu 18.04 on my PC equipped with Geforce 1080.
I reinstalled NVIDIA drivers (new version 470.86) with ubuntu-drivers autoinstall.
When I run nvidia-smi I receive
| NVIDIA-SMI 470.82.00 Driver Version: 470.86 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:65:00.0 On | N/A |
| 0% 34C P8 9W / 180W | 253MiB / 8111MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1347 G /usr/bin/gnome-shell 59MiB |
| 0 N/A N/A 1875 G /usr/bin/gnome-shell 175MiB |
However, when I run nvidia-settings command I receive:
ERROR: Unable to find display on any available system
(nvidia-settings:7072): GLib-GObject-CRITICAL **: 17:57:37.743: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
** Message: 17:57:37.750: PRIME: No offloading required. Abort
** Message: 17:57:37.750: PRIME: is it supported? no
I have Secure Boot disabled.
Please help.
Thank you very much
nvidia-bug-report.log.gz (1.0 MB)
You’re running a Wayland session, nvidia-settings is X11 only.
@generix
I wonder what in the logs is telling that the OP is running a Wayland session. I was looking for clues, but can’t tell. You mind helping me out there?
No Xserver process.
