(nvidia-settings:7578): GLib-GObject-CRITICAL **: 12:00:43.745: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Hi!
I’m working on msi creator 17m laptop with 1660ti integrated nvidia gpu
W/o any updates installatios my external display stopped working today
Checked some forum topics, used some commands:
$ nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
** Message: 12:00:43.748: PRIME: Requires offloading
** Message: 12:00:43.748: PRIME: is it supported? yes
** Message: 12:00:43.770: PRIME: Usage: /usr/bin/prime-select nvidia|intel|on-demand|query
** Message: 12:00:43.770: PRIME: on-demand mode: "1"
** Message: 12:00:43.770: PRIME: is "on-demand" mode supported? yes
$ dkms status
nvidia, 470.82.00, 5.11.0-40-generic, x86_64: installed
so looks like the driver doesn’t work?
generated bug report
nvidia-bug-report.log.gz (184.8 KB)
could you plz recommend me smth?
secureboot: Secure boot enabled
Please try disabling secure boot in bios
Thx. It hepled!
Could you pls describe how did you find this solution?
Is it a common problem with drivers+secure boot?
The logs contain the output of
lspci -k
which lists modules available and modules in use. nvidia was available but not used (and also no other one), which has three posible reasons, from most to least common:
  1. secure boot enabled and module is unsigned
  2. module is blacklisted
  3. module is incompatible
So first search fore “secure” in dmesg output leads to the message. (sudo dmesg |grep -i secure)
Interesting!
Thank you!
