I get the following error message when I pass the nvidia-settings command on ubuntu 18.04 Nvidia GPU is RTX 2080 MAX Q.
b: GLib-GObject-CRITICAL **: 09:42:14.690: g_object_unref: assertion ‘G_IS_OBJECT (object)’ failed
** Message: 09:42:15.121: PRIME: Requires offloading
** Message: 09:42:15.121: PRIME: is it supported? yes[b][/b][/b]
nvidia-smi returns the following
[b]Tue Oct 1 09:55:08 2019
| NVIDIA-SMI 418.88 Driver Version: 418.88 CUDA Version: 10.1 |
| 0 GeForce RTX 208… On | 00000000:01:00.0 Off | N/A |
| N/A 38C P8 6W / N/A | 378MiB / 7952MiB | 4% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 1565 G /usr/lib/xorg/Xorg 170MiB |
| 0 1736 G /usr/bin/gnome-shell 113MiB |
| 0 2121 G …quest-channel-token=5713608614134157389 92MiB |
±----------------------------------------------------------------------------+[/b]
1)Should I be worried about this error?
2)Also please have a look at my nvidia bug report file and let me know if there is any other issue with my GPU.
nvidia-bug-report.log.gz (1.24 MB)
nvidia-bug-report.log (3.59 MB)
