I just install Tesla C1060 and the latest driver NVIDIA-Linux-x86_64-185.18.36_pkg2.run.
Using nvidia-settings, the graphic interface shown as attached.
It says The Bus type: PCI Express 8X, and IRQ 30.
It looks strange to me. As another GeForce9500 GT, which is used as a normal graphic card, was shown with Bus Type: PCI Express 16X.
I’m not sure if I installed the hardware or the driver correctly. The figure on the installation guide shows it should be PCI Express 16X. Anybody knows what’s going on here? Thanks a lot.
I got some warning at the very end: ‘unable to perform runtime configuration check for library libGL.so.1.0-9746’.
I checked the /var/log/Xorg.0.log. It does not contain any errors (EE), as follow:
X.Org X Server 1.6.0
Release Date: 2009-2-25
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.24-15-server x86_64 Ubuntu
Current Operating System: Linux minint-7rsffa6e 2.6.28-15-generic #49-Ubuntu SMP Tue Aug 18 19:25:34 UTC 2009 x86_64
Build Date: 09 April 2009 02:11:54AM
xorg-server 2:1.6.0-0ubuntu14 (buildd@crested.buildd)
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: “/var/log/Xorg.0.log”, Time: Sat Aug 29 00:13:22 2009
(==) Using config file: “/etc/X11/xorg.conf”
(==) ServerLayout “Layout0”
() |–>Screen “Screen0” (0)
() | |–>Monitor “Monitor0”
() | |–>Device “Device0”
() |–>Input Device “Keyboard0”
() |–>Input Device “Mouse0”
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(==) ModulePath set to “/usr/lib/xorg/modules”
(WW) AllowEmptyInput is on, devices using drivers ‘kbd’, ‘mouse’ or ‘vmmouse’ will be disabled.
(WW) Disabling Keyboard0
(WW) Disabling Mouse0
(II) Loader magic: 0xb40
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 5.0
X.Org XInput driver : 4.0
X.Org Server Extension : 2.0
(II) Loader running on linux
(++) using VT number 7
(–) PCI:*(0@2:0:0) nVidia Corporation GeForce 9500 GT rev 161, Mem @ 0xca000000/16777216, 0xb0000000/268435456, 0xc8000000/33554432, I/O @ 0x00002000/128
(II) Open ACPI successful (/var/run/acpid.socket)
(II) System resource ranges:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
(II) LoadModule: “extmod”
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor=“X.Org Foundation”
compiled for 1.6.0, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: “dbe”
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor=“X.Org Foundation”
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: “glx”
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor=“NVIDIA Corporation”
compiled for 4.0.2, module version = 1.0.0
(II) NVIDIA GLX Module 185.18.36 Fri Aug 14 18:27:24 PDT 2009
(II) Loading extension GLX
(II) LoadModule: “record”
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor=“X.Org Foundation”
compiled for 1.6.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: “dri”
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor=“X.Org Foundation”
(II) Loading extension XFree86-DRI
(II) LoadModule: “dri2”
(II) Loading /usr/lib/xorg/modules/extensions//libdri2.so
(II) Module dri2: vendor=“X.Org Foundation”
(II) Loading extension DRI2
(II) LoadModule: “nvidia”
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor=“NVIDIA Corporation”
Module class: X.Org Video Driver
(II) NVIDIA dlloader X Driver 185.18.36 Fri Aug 14 17:51:02 PDT 2009
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 02@00:00:0
(II) Loading sub module “fb”
(II) LoadModule: “fb”
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor=“X.Org Foundation”
ABI class: X.Org ANSI C Emulation, version 0.4
(II) Loading sub module “wfb”
(II) LoadModule: “wfb”
(II) Loading /usr/lib/xorg/modules//libwfb.so
(II) Module wfb: vendor=“X.Org Foundation”
(II) Loading sub module “ramdac”
(II) LoadModule: “ramdac”
(II) Module “ramdac” already built-in
(II) resource ranges after probing:
() NVIDIA(0): Depth 24, (–) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
() NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): Support for GLX with the Damage and Composite X extensions is
(II) NVIDIA(0): enabled.
(II) NVIDIA(0): NVIDIA GPU GeForce 9500 GT (G96) at PCI:2:0:0 (GPU-0)
(–) NVIDIA(0): Memory: 524288 kBytes
(–) NVIDIA(0): VideoBIOS: 62.94.35.00.28
(II) NVIDIA(0): Detected PCI Express Link width: 16X
(–) NVIDIA(0): Interlaced video modes are supported on this GPU
(–) NVIDIA(0): Connected display device(s) on GeForce 9500 GT at PCI:2:0:0:
(–) NVIDIA(0): Acer V223W (DFP-0)
(–) NVIDIA(0): Acer V223W (DFP-0): 330.0 MHz maximum pixel clock
(–) NVIDIA(0): Acer V223W (DFP-0): Internal Dual Link TMDS
(II) NVIDIA(0): Assigned Display Device: DFP-0
(==) NVIDIA(0):
(==) NVIDIA(0): No modes were requested; the default mode “nvidia-auto-select”
(==) NVIDIA(0): will be used as the requested mode.
(==) NVIDIA(0):
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0): “nvidia-auto-select”
(II) NVIDIA(0): Virtual screen size determined to be 1680 x 1050
(–) NVIDIA(0): DPI set to (90, 88); computed from “UseEdidDpi” X config
(–) NVIDIA(0): option
(==) NVIDIA(0): Enabling 32-bit ARGB GLX visuals.
(–) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
(II) NVIDIA(0): Implicitly enabling NoScanout
(II) NVIDIA(GPU-1): NVIDIA GPU Tesla C1060 (GT200) at PCI:3:0:0 (GPU-1)
(–) NVIDIA(GPU-1): Memory: 4194304 kBytes
(–) NVIDIA(GPU-1): VideoBIOS: 62.00.62.00.07
(II) NVIDIA(GPU-1): Detected PCI Express Link width: 8X
(–) NVIDIA(GPU-1): Interlaced video modes are supported on this GPU
(–) NVIDIA(GPU-1): Connected display device(s) on Tesla C1060 at PCI:3:0:0:
(II) NVIDIA(0): Initialized GPU GART.
(II) NVIDIA(0): Setting mode “nvidia-auto-select”
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(==) NVIDIA(0): Disabling shared memory pixmaps
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Silken mouse enabled
() Option “dpms”
() NVIDIA(0): DPMS enabled
(II) Loading extension NV-CONTROL
(II) Loading extension XINERAMA
(==) RandR enabled
(II) Initializing built-in extension Generic Event Extension
(II) Initializing built-in extension SHAPE
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension BIG-REQUESTS
(II) Initializing built-in extension SYNC
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-MISC
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing extension GLX
(II) config/hal: Adding input device Microsoft Comfort Curve Keyboard 2000
(II) LoadModule: “evdev”
(II) Loading /usr/lib/xorg/modules/input//evdev_drv.so
(II) Module evdev: vendor=“X.Org Foundation”
compiled for 1.6.0, module version = 2.1.1
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 4.0
() Microsoft Comfort Curve Keyboard 2000: always reports core events
() Microsoft Comfort Curve Keyboard 2000: Device: “/dev/input/event8”
(II) Microsoft Comfort Curve Keyboard 2000: Found 1 mouse buttons
(II) Microsoft Comfort Curve Keyboard 2000: Found keys
(II) Microsoft Comfort Curve Keyboard 2000: Configuring as keyboard
() Microsoft Comfort Curve Keyboard 2000: YAxisMapping: buttons 4 and 5
() Microsoft Comfort Curve Keyboard 2000: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device “Microsoft Comfort Curve Keyboard 2000” (type: KEYBOARD)
() Option “xkb_rules” “evdev”
() Microsoft Comfort Curve Keyboard 2000: xkb_rules: “evdev”
() Option “xkb_model” “pc105”
() Microsoft Comfort Curve Keyboard 2000: xkb_model: “pc105”
() Option “xkb_layout” “us”
() Microsoft Comfort Curve Keyboard 2000: xkb_layout: “us”
(II) config/hal: Adding input device American Megatrends Inc. Virtual Keyboard and Mouse
() American Megatrends Inc. Virtual Keyboard and Mouse: always reports core events
() American Megatrends Inc. Virtual Keyboard and Mouse: xkb_rules: “evdev”
() American Megatrends Inc. Virtual Keyboard and Mouse: xkb_model: “pc105”
() American Megatrends Inc. Virtual Keyboard and Mouse: xkb_layout: “us”
() Microsoft Comfort Curve Keyboard 2000: Device: “/dev/input/event7”
(II) config/hal: Adding input device Macintosh mouse button emulation
() Macintosh mouse button emulation: always reports core events
() Macintosh mouse button emulation: Device: “/dev/input/event2”
(II) Macintosh mouse button emulation: Found 3 mouse buttons
(II) Macintosh mouse button emulation: Found x and y relative axes
(II) Macintosh mouse button emulation: Configuring as mouse
() Macintosh mouse button emulation: YAxisMapping: buttons 4 and 5
() Macintosh mouse button emulation: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device “Macintosh mouse button emulation” (type: MOUSE)
() Macintosh mouse button emulation: (accel) keeping acceleration scheme 1
() Macintosh mouse button emulation: (accel) filter chain progression: 2.00
() Macintosh mouse button emulation: (accel) filter stage 0: 20.00 ms
() Macintosh mouse button emulation: (accel) set acceleration profile 0
(II) config/hal: Adding input device Microsoft Microsoft 3-Button Mouse with IntelliEye™
() Microsoft Microsoft 3-Button Mouse with IntelliEye™: always reports core events
() Microsoft Microsoft 3-Button Mouse with IntelliEye™: Device: “/dev/input/event6”
(II) Microsoft Microsoft 3-Button Mouse with IntelliEye™: Found 3 mouse buttons
(II) Microsoft Microsoft 3-Button Mouse with IntelliEye™: Found x and y relative axes
(II) Microsoft Microsoft 3-Button Mouse with IntelliEye™: Configuring as mouse
() Microsoft Microsoft 3-Button Mouse with IntelliEye™: YAxisMapping: buttons 4 and 5
() Microsoft Microsoft 3-Button Mouse with IntelliEye™: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device “Microsoft Microsoft 3-Button Mouse with IntelliEye™” (type: MOUSE)
() Microsoft Microsoft 3-Button Mouse with IntelliEye™: (accel) keeping acceleration scheme 1
() Microsoft Microsoft 3-Button Mouse with IntelliEye™: (accel) filter chain progression: 2.00
() Microsoft Microsoft 3-Button Mouse with IntelliEye™: (accel) filter stage 0: 20.00 ms
() Microsoft Microsoft 3-Button Mouse with IntelliEye™: (accel) set acceleration profile 0
() American Megatrends Inc. Virtual Keyboard and Mouse: Device: “/dev/input/event5”
(II) American Megatrends Inc. Virtual Keyboard and Mouse: Found 3 mouse buttons
(II) American Megatrends Inc. Virtual Keyboard and Mouse: Found x and y absolute axes
(II) American Megatrends Inc. Virtual Keyboard and Mouse: Configuring as mouse
() American Megatrends Inc. Virtual Keyboard and Mouse: YAxisMapping: buttons 4 and 5
() American Megatrends Inc. Virtual Keyboard and Mouse: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
(II) XINPUT: Adding extended input device “American Megatrends Inc. Virtual Keyboard and Mouse” (type: MOUSE)
() American Megatrends Inc. Virtual Keyboard and Mouse: (accel) keeping acceleration scheme 1
() American Megatrends Inc. Virtual Keyboard and Mouse: (accel) filter chain progression: 2.00
() American Megatrends Inc. Virtual Keyboard and Mouse: (accel) filter stage 0: 20.00 ms
(**) American Megatrends Inc. Virtual Keyboard and Mouse: (accel) set acceleration profile 0
