I got a new system (Lenovo ideapad Gaming 3) and installed kali linux in same.
Below are some command outputs
Kernal
└─$ uname -a
Linux Kali 6.5.0-kali3-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.5.6-1kali1 (2023-10-09) x86_64 GNU/Linux
Current OS Version
└─$ lsb_release -a
No LSB modules are available.
Distributor ID: Kali
Description: Kali GNU/Linux Rolling
Release: 2023.4
Codename: kali-rolling
Graphic card
└─$ lspci | grep VGA
01:00.0 VGA compatible controller: NVIDIA Corporation AD107M [GeForce RTX 4050 Max-Q / Mobile] (rev a1)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Rembrandt [Radeon 680M] (rev 0a)
Below is output for nvidia-detect
└─$ nvidia-detect
Detected NVIDIA GPUs:
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation AD107M [GeForce RTX 4050 Max-Q / Mobile] [10de:28a1] (rev a1)
Checking card: NVIDIA Corporation AD107M [GeForce RTX 4050 Max-Q / Mobile] (rev a1)
Uh oh. Failed to identify your Debian suite.
Below is output for nvidia-smi
└─$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
FYI Secure boot is disabled
└─$ sudo mokutil --sb-state
SecureBoot disabled
I also tried reinstalling drivers multiple times. Still didn’t work. Below is the command i used to install
sudo apt install -y nvidia-driver nvidia-cuda-toolkit
nvidia-persistenced.service Status
└─$ sudo systemctl status nvidia-persistenced.service
○ nvidia-persistenced.service - NVIDIA Persistence Daemon
Loaded: loaded (/usr/lib/systemd/system/nvidia-persistenced.service; disabled; preset: disabled)
Active: inactive (dead)
When ran nvidia-persistenced.service start
└─$ sudo systemctl start nvidia-persistenced.service
Job for nvidia-persistenced.service failed because the control process exited with error code.
See "systemctl status nvidia-persistenced.service" and "journalctl -xeu nvidia-persistenced.service" for details.
Below are few more logs related to same
└─$ systemctl status nvidia-persistenced.service
× nvidia-persistenced.service - NVIDIA Persistence Daemon
Active: failed (Result: exit-code) since Tue 2024-01-30 20:09:38 IST; 49s ago
Process: 5373 ExecStart=/usr/bin/nvidia-persistenced --user nvpd (code=exited, status=1/FAILURE)
Process: 5380 ExecStopPost=/bin/rm -rf /var/run/nvidia-persistenced (code=exited, status=0/SUCCESS)
CPU: 30ms
Jan 30 20:09:38 Kali systemd[1]: Starting nvidia-persistenced.service - NVIDIA Persistence Daemon...
Jan 30 20:09:38 Kali nvidia-persistenced[5374]: Started (5374)
Jan 30 20:09:38 Kali nvidia-persistenced[5374]: Failed to query NVIDIA devices. Please ensure that the NVIDIA device files (/dev/nvidia*) exist, and that user 133>
Jan 30 20:09:38 Kali nvidia-persistenced[5374]: Shutdown (5374)
Jan 30 20:09:38 Kali nvidia-persistenced[5373]: nvidia-persistenced failed to initialize. Check syslog for more details.
Jan 30 20:09:38 Kali systemd[1]: nvidia-persistenced.service: Control process exited, code=exited, status=1/FAILURE
Jan 30 20:09:38 Kali systemd[1]: nvidia-persistenced.service: Failed with result 'exit-code'.
Jan 30 20:09:38 Kali systemd[1]: Failed to start nvidia-persistenced.service - NVIDIA Persistence Daemon.
GCC version in case needed
└─$ gcc --version
gcc (Debian 13.2.0-7) 13.2.0
Attaching nvidia bug report file
nvidia-bug-report.log.gz (123.5 KB)
