NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver after updating Ubuntu 20.04
I have an Ubuntu 20.04 system which has been working perfectly with an nvidia 1080Ti card.
I recently allowed the software updater on ubuntu to install some pending updates and my nvidia card stopped working.
I did not upgrade to ubuntu-20.04 from a previous version of ubuntu. This system has been running ubuntu-20.04 for a while with no issues, and I just allowed some updates to be installed.
Only one of my three attached monitors works now and when I run the nvidia-settings app, I get a small blank screen instead of seeing the nvidia settings listed.
I think this is because nvidia driver is not loading anymore :
$ sudo prime-select query
nvidia
$ nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Here is some additional information which may assist in diagnosing what is wrong:
$ dkms status
nvidia, 460.39, 5.8.0-45-generic, x86_64: installed (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!) (WARNING! Diff between built and installed module!)
virtualbox, 6.1.16, 5.8.0-44-generic, x86_64: installed
virtualbox, 6.1.16, 5.8.0-45-generic, x86_64: installed
$ grep -r nvidia /etc/modprobe.d/* /lib/modprobe.d/*
/etc/modprobe.d/blacklist-framebuffer.conf:blacklist nvidiafb
 uname -a
Linux shed-ubuntu 5.8.0-45-generic #51~20.04.1-Ubuntu SMP Tue Feb 23 13:46:31 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
I am attaching debug logs:
nvidia-bug-report.log.gz (106.1 KB)
Please run
grep nvidia /etc/modprobe.d/* /lib/modprobe.d/*
to find a file containing
blacklist nvidia
and remove it,
then run
sudo update-initramfs -u
and reboot.
Thank you for the quick response. I showed the output of grep nvidia /etc/modprobe.d/* /lib/modprobe.d/* in the original post.
This is what the grep finds: /etc/modprobe.d/blacklist-framebuffer.conf:blacklist nvidiafb
Is it correct to remove (or comment out) that entry, update the ramfs and reboot?
That file has to stay where it is.
The driver is installed and avalable, it just doesn’t load. Please try updating the initrd
Can you manually load the driver?
sudo modprobe nvidia
I tried:
sync
reboot
and it had no effect (no difference in behavior).
I then tried:
$ sudo modprobe nvidia
modprobe: ERROR: could not insert 'nvidia': Key was rejected by service
Please removing and adding the modules:
sudo dkms remove nvidia/460.39 --all
sudo dkms install nvidia/460.39 -k $(uname -r)
@generix - thank you very much for your help. Your instructions above for removing and re-installing the nvidia kernel modules worked for me.
I did make one change to the commands you cited above.
When I ran the dkms install command, I got quite a few messages like this:
Good news! Module version 460.39 for nvidia.ko
exactly matches what is already found in kernel 5.8.0-45-generic.
DKMS will not replace this module.
You may override by specifying --force.
So I decided to install the kernel modules using the --force option to make sure they got updated. That seemed to work. Here are the commands that I ran:
sudo dkms install --force nvidia/460.39 -k $(uname -r)
sync
reboot
Thank you again for all of your help!
I have have a similar problem running on a VPX PC and the WOLF P5000.
$sudo prime-select query
nvidia
$nvidia-smi
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
$ dkms status
nvidia, 465.27, 5.8.0-43-generic, x86_64: installed
nvidia, 465.27, 5.8.0-53-generic, x86_64: installed
$ dmesg
[ 1272.612381] NVRM: None of the NVIDIA devices were initialized.
[ 1272.612824] nvidia-nvlink: Unregistered the Nvlink Core, major device number 511
[ 1273.231616] nvidia-nvlink: Nvlink Core is being initialized, major device number 511
[ 1273.232286] NVRM: request_mem_region failed for 0M @ 0x0. This can
NVRM: occur when a driver such as rivatv is loaded and claims
NVRM: ownership of the device’s registers.
[ 1273.232290] nvidia: probe of 0000:04:00.0 failed with error -1
[ 1273.232307] NVRM: The NVIDIA probe routine failed for 1 device(s).
[ 1273.232308] NVRM: None of the NVIDIA devices were initialized.
$uname -a
Linux tre-TR-E8x-msd 5.8.0-53-generic #60~20.04.1-Ubuntu SMP Thu May 6 09:52:46 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
nvidia-bug-report.log.gz (1.3 MB)
Hey all.
When I run nvidia-smi, I get the following output:
dkms status:
nvidia, 470.57.02: added
nvidia-settings:
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
The NVIDIA x server settings window which opens after the command above is empty.
Here’s a bug report: nvidia-bug-report.log.gz (95.9 KB)
I’m using Ubuntu 20.04 LTS. I needed to update the kernel to 5.13.7 because the touchpad wasn’t working properly on 5.8. This update might have caused the problem I’m facing right now.
Any advice on how to fix the problem? Thanks!
I have the same problem with exact same outputs. Please help!
I disabled the Secure Boot on my machine and now nvidia-smi works.
Wow, it’s work for me, Thanks @tolkjenkot
Hi there, I ran into this problem recently and found your solution very useful. Thank you very much! :)
Thanks a lot, I used dual boot with Win11, and the secure boot is the problem. Unable it solve the error
thanks
I am facing the same issue and was not able to fix this, but worked after disabling the secure boot
Fixed my missing GPU problem as well (with replacing driver as 470.74 instead of 460.39 above) . I had updated a new kernel (because of sound problems of my laptop) but that had messed up my nvidia driver. Returned to default kernel and it is now working fine. My system is ubuntu 20.10, driver 470.74, kernel 5.11.0-38-generic , lenovo yoga laptop with GEFORCE GPX GPU.
i solved it after deleting all installed nvidia package and re-install it from selecting newest driver nvidia in Software & Update
apt purge nvidia*
then
select ur driver in Software & Update (Apply Change)
then, open again
nvidia-smi
it work for me
This works for me. Thank you!
