Hello, for some reason I can’t use my GPU anymore. nvidia-smi gives the following error message : “NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.”
I have tried various fixes mentioned in others thread (disable secure boot, update gcc, update init-rampf) without success.
Here is my bug report nvidia-bug-report.log.gz (203.2 KB)
I’m using ubuntu 20 and a dell g3.
There doesn’t seem to be a kernel driver installed and nouveau is enabled. Please check if you’re boting the correct kernel version. Please also post the output of
dkms status
Please use Software&Updates to install the latest available nvidia driver.
On reboot, hold down shift to open the grub menu, check which kernel versions are available and boot the highest one.
After boot, please create a new nvidia-bug-report.log and post the output of
dkms status
Using command line, I can’t install any nvidia driver version. I get an error “impossible to correct issues, defectuous packages are in “stay in current state” mode”
I am also facing similar issue on my machine ( Dell G3 3590) I have upgraded machine from 18.04 to 20.04 recently. It was working perfect on 18.04 but on 20.04 seems to be its installed but can’t enable as active one. So could you please help me ?
Here is my output of some requested commands:
sunil@sunil-G3-3590:~$ uname -a
Linux sunil-G3-3590 5.4.0-66-generic #74-Ubuntu SMP Wed Jan 27 22:54:38 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
