Hi,I have a virtual machine running Ubuntu 20.04 server, based on Esxi 8.0, with a GTX1650 graphics card passed through to the virtual machine(for hardware acceleration to perform operations related to decoding and encoding video streams). I have tried to install the nvidia driver by running ubuntu-drivers devices command to get the recommended driver and apt install nvidia-driver-525 to install,then nvidia-smi to test the installation but got “No devices were found” with no luck.
Recently, I’ve tried many ways to work it out by running different ubuntu distributions VMs(18.04,22.04),and different versions of nvidia drivers such as 460,470,but still got the ‘No devices were found’ :(
ps.
- Graphics card works fine on win10 which directly run on physical machine.
- Also can be detected by
lspci
Here is my hardware list(which running the esxi8.0) below,
CPU: Intel 6700
Mainboard: Asrock H270M Pro4
GPU: Onda GeForce 1650 4G DDR6(TU116)
Could anyone give me some help? Sincerely thanks.
Bug report attached.
nvidia-bug-report.log (1.6 MB)
Please set kenel parameter
nvidia.NVreg_OpenRmEnableUnsupportedGpus=1
Thanks for your reply!
After doing some search, I rebuilt Ubuntu server 22.04.2 LTS VM and install nvidia drivers following by this.
Unfortunately,I got ‘No devices were found’ again. :(
dmesg | grep NV
output:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000000fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000fbfb000-0x000000000fbfefff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x0000000000000000-0x0000000000000fff] ACPI NVS
[ 0.000000] reserve setup_data: [mem 0x000000000fbfb000-0x000000000fbfefff] ACPI NVS
[ 0.121946] ACPI: PM: Registering ACPI NVS region [mem 0x00000000-0x00000fff] (4096 bytes)
[ 0.121946] ACPI: PM: Registering ACPI NVS region [mem 0x0fbfb000-0x0fbfefff] (16384 bytes)
[ 0.125703] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 7.045276] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:02/0000:02:05.1/sound/card0/input6
[ 7.045652] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:02/0000:02:05.1/sound/card0/input7
[ 7.045726] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:02/0000:02:05.1/sound/card0/input8
[ 7.047872] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:02/0000:02:05.1/sound/card0/input9
[ 7.047950] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:02/0000:02:05.1/sound/card0/input10
[ 7.048024] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:02/0000:02:05.1/sound/card0/input11
[ 598.548112] NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 525.89.02 Release Build (dvs-builder@U16-F11-34-6) Wed Feb 1 23:19:51 UTC 2023
[ 598.576564] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 525.89.02 Release Build (dvs-builder@U16-F11-34-6) Wed Feb 1 23:10:24 UTC 2023
[ 612.396778] NVRM: loading NVIDIA UNIX Open Kernel Module for x86_64 525.89.02 Release Build (dvs-builder@U16-F11-34-6) Wed Feb 1 23:19:51 UTC 2023
[ 612.402809] nvidia-modeset: Loading NVIDIA UNIX Open Kernel Mode Setting Driver for x86_64 525.89.02 Release Build (dvs-builder@U16-F11-34-6) Wed Feb 1 23:10:24 UTC 2023
[ 801.049919] NVRM tmrSetCurrentTime_GV100: ERROR: Write to PTIMER attempted even though Level 0 PLM is disabled.
[ 801.049921] NVRM nvAssertFailedNoLog: Assertion failed: 0 @ timer_gv100.c:80
[ 805.048201] NVRM _threadNodeCheckTimeout: _threadNodeCheckTimeout: currentTime: 3d09757cbdff00 >= 3d09757cbdff00
[ 805.048204] NVRM _threadNodeCheckTimeout: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs!
[ 805.048207] NVRM kflcnWaitForHalt_TU102: Timeout waiting for Falcon to halt
[ 805.048208] NVRM s_executeFwsec_TU102: failed to execute FWSEC cmd 0x15: status 0x65
[ 805.048223] NVRM nvAssertOkFailedNoLog: Assertion failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from kgspExecuteFwsecFrts_HAL(pGpu, pKernelGsp, pKernelGsp->pFwsecUcode, pKernelGsp->pWprMeta->frtsOffset) @ kernel_gsp_tu102.c:363
[ 805.048226] NVRM kgspInitRm_IMPL: cannot bootstrap riscv/gsp: 0x65
[ 805.048229] NVRM RmInitAdapter: Cannot initialize GSP firmware RM
[ 805.049722] NVRM: GPU 0000:02:05.0: RmInitAdapter failed! (0x62:0x65:1615)
[ 805.050481] NVRM: GPU 0000:02:05.0: rm_init_adapter failed, device minor number 0
[ 805.183959] NVRM tmrSetCurrentTime_GV100: ERROR: Write to PTIMER attempted even though Level 0 PLM is disabled.
[ 805.183961] NVRM nvAssertFailedNoLog: Assertion failed: 0 @ timer_gv100.c:80
[ 805.271495] NVRM s_executeBooterUcode_TU102: Booter failed with non-zero error code: 0xff
[ 805.271497] NVRM kgspExecuteBooterUnloadIfNeeded_TU102: failed to execute Booter Unload: 0xffff
[ 809.180192] NVRM _threadNodeCheckTimeout: _threadNodeCheckTimeout: currentTime: 3d097673075000 >= 3d097673075000
[ 809.180196] NVRM _threadNodeCheckTimeout: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs!
[ 809.180211] NVRM kflcnWaitForHalt_TU102: Timeout waiting for Falcon to halt
[ 809.180213] NVRM s_executeFwsec_TU102: failed to execute FWSEC cmd 0x15: status 0x65
[ 809.180215] NVRM nvAssertOkFailedNoLog: Assertion failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from kgspExecuteFwsecFrts_HAL(pGpu, pKernelGsp, pKernelGsp->pFwsecUcode, pKernelGsp->pWprMeta->frtsOffset) @ kernel_gsp_tu102.c:363
[ 809.180231] NVRM kgspInitRm_IMPL: cannot bootstrap riscv/gsp: 0x65
[ 809.180235] NVRM RmInitAdapter: Cannot initialize GSP firmware RM
[ 809.181631] NVRM: GPU 0000:02:05.0: RmInitAdapter failed! (0x62:0x65:1615)
[ 809.182382] NVRM: GPU 0000:02:05.0: rm_init_adapter failed, device minor number 0
[ 847.591908] NVRM tmrSetCurrentTime_GV100: ERROR: Write to PTIMER attempted even though Level 0 PLM is disabled.
[ 847.591913] NVRM nvAssertFailedNoLog: Assertion failed: 0 @ timer_gv100.c:80
[ 847.678182] NVRM s_executeBooterUcode_TU102: Booter failed with non-zero error code: 0xff
[ 847.678184] NVRM kgspExecuteBooterUnloadIfNeeded_TU102: failed to execute Booter Unload: 0xffff
[ 851.588217] NVRM _threadNodeCheckTimeout: _threadNodeCheckTimeout: currentTime: 3d098052be0a00 >= 3d098052be0a00
[ 851.588220] NVRM _threadNodeCheckTimeout: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs!
[ 851.588235] NVRM kflcnWaitForHalt_TU102: Timeout waiting for Falcon to halt
[ 851.588237] NVRM s_executeFwsec_TU102: failed to execute FWSEC cmd 0x15: status 0x65
[ 851.588239] NVRM nvAssertOkFailedNoLog: Assertion failed: Call timed out [NV_ERR_TIMEOUT] (0x00000065) returned from kgspExecuteFwsecFrts_HAL(pGpu, pKernelGsp, pKernelGsp->pFwsecUcode, pKernelGsp->pWprMeta->frtsOffset) @ kernel_gsp_tu102.c:363
New bug report attached.
nvidia-bug-report.log.gz (64.4 KB)
Is the needed firmware file installed? Did you install the driver using “Software&Updates”?
“Software&Updates” is a function of Ubuntu Desktop? I’m runing an Ubuntu Server edition.
I followed these steps exactly to install.
touch /etc/modprobe.d/blacklist-nvidia-nouveau.conf
cat >> /etc/modprobe.d/blacklist-nvidia-nouveau.conf << EOF
blacklist nouveau
options nouveau modeset=0
EOF
touch /etc/modprobe.d/nvidia.conf
cat >> /etc/modprobe.d/nvidia.conf << EOF
options nvidia NVreg_OpenRmEnableUnsupportedGpus=1
EOF
sudo update-initramfs -u
sudo reboot
wget https://download.nvidia.com/XFree86/Linux-x86_64/525.89.02/NVIDIA-Linux-x86_64-525.89.02.run
sudo chmod u+x NVIDIA-Linux-x86_64-525.89.02.run
sudo apt install build-essential
sudo apt install pkg-config libglvnd-dev
./NVIDIA-Linux-x86_64-525.89.02.run -m=kernel-open
… Could you please tell me what is the needed firmware file?
Should be installed in /lib/firmware/nvidia/525.89.02/ named gsp_ga10x.bin and gsp_tu10.bin
