I just installed Ubuntu 22.04 LTS. I have GeForce GTX 1650 Ti but nothing is showing when running nvidia-smi. I tried multiple times using additional drivers: nvidia-driver-530, 525, open kernel 525 ,open kernel 530,etc. But no effect in output.
Some screenshots:
https://drive.google.com/drive/folders/1zCxtwcOApeQ2imleDGrXyr7vK9dXI_CJ?usp=sharing
Some cmds i tried:
anish@anish:~$ nvidia-smi
No devices were found
anish@anish:~$ lshw -c video
WARNING: you should run this program as super-user.
*-display
description: VGA compatible controller
product: TU117M [GeForce GTX 1650 Ti Mobile]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:92 memory:c1000000-c1ffffff memory:90000000-9fffffff memory:a0000000-a1ffffff ioport:3000(size=128) memory:c2080000-c20fffff
*-display
product: Renoir
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:05:00.0
logical name: /dev/fb0
version: c7
width: 64 bits
clock: 33MHz
capabilities: vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=amdgpu latency=0 resolution=1920,1080
resources: irq:46 memory:b0000000-bfffffff memory:c0000000-c01fffff ioport:1000(size=256) memory:c2500000-c257ffff memory:c0000-dffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
anish@anish:~$ sudo lshw -c video
*-display
physical id: 0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
*-display
product: Renoir
physical id: 0
version: c7
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list rom fb
anish@anish:~$ systemctl status nvidia-persistenced.service
● nvidia-persistenced.service - NVIDIA Persistence Daemon
Loaded: loaded (/lib/systemd/system/nvidia-persistenced.service; static)
Active: active (running) since Mon 2023-04-24 10:35:35 +0545; 16min ago
Process: 976 ExecStart=/usr/bin/nvidia-persistenced --user nvidia-persisten>
Main PID: 977 (nvidia-persiste)
Tasks: 1 (limit: 8680)
Memory: 772.0K
CPU: 3ms
CGroup: /system.slice/nvidia-persistenced.service
└─977 /usr/bin/nvidia-persistenced --user nvidia-persistenced --no>
अप्रैल 24 10:35:35 anish systemd[1]: Starting NVIDIA Persistence Daemon...
अप्रैल 24 10:35:35 anish nvidia-persistenced[977]: Verbose syslog connection open>
अप्रैल 24 10:35:35 anish nvidia-persistenced[977]: Now running with user ID 129 a>
अप्रैल 24 10:35:35 anish nvidia-persistenced[977]: Started (977)
अप्रैल 24 10:35:35 anish nvidia-persistenced[977]: device 0000:01:00.0 - register>
अप्रैल 24 10:35:35 anish nvidia-persistenced[977]: Local RPC services initialized
अप्रैल 24 10:35:35 anish systemd[1]: Started NVIDIA Persistence Daemon.
anish@anish:~$ lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU117M [GeForce GTX 1650 Ti Mobile] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
02:00.0 Non-Volatile memory controller: SK hynix BC511
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
04:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c7)
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01)
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
anish@anish:~$ sudo nvidia-bug-report.sh
nvidia-bug-report.sh will now collect information about your
system and create the file 'nvidia-bug-report.log.gz' in the current
directory. It may take several seconds to run. In some
cases, it may hang trying to capture data generated dynamically
by the Linux kernel and/or the NVIDIA kernel module. While
the bug report log file will be incomplete if this happens, it
may still contain enough data to diagnose your problem.
If nvidia-bug-report.sh hangs, consider running with the --safe-mode
and --extra-system-data command line arguments.
Please include the 'nvidia-bug-report.log.gz' log file when reporting
your bug via the NVIDIA Linux forum (see forums.developer.nvidia.com)
or by sending email to 'linux-bugs@nvidia.com'.
By delivering 'nvidia-bug-report.log.gz' to NVIDIA, you acknowledge
and agree that personal information may inadvertently be included in
the output. Notwithstanding the foregoing, NVIDIA will use the
output only for the purpose of investigating your reported issue.
Running nvidia-bug-report.sh... complete.
