Nvidia-smi outputs "No devices were found" on Ubuntu 22.04 + driver 520 + Nuvo-8208GC
nvidia-bug-report.log.gz (181.4 KB)
I’m having trouble finding the device on nvidia-smi right now.
environment
$ uname -a
Linux autoware 5.15.0-53-generic #59-Ubuntu SMP Mon Oct 17 18:53:30 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
$ lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 22.04 LTS
Release:        22.04
Codename:       jammy
$ lspci | grep -i nvidia
06:00.0 VGA compatible controller: NVIDIA Corporation GA104 [GeForce RTX 3060] (rev a1)
06:00.1 Audio device: NVIDIA Corporation GA104 High Definition Audio Controller (rev a1)
$ lshw -c video
WARNING: you should run this program as super-user.
  *-display
       description: VGA compatible controller
       product: GA104 [GeForce RTX 3060]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:06:00.0
       version: a1
       width: 64 bits
       clock: 33MHz
       capabilities: vga_controller bus_master cap_list rom
       configuration: driver=nvidia latency=0
       resources: irq:17 memory:96000000-96ffffff memory:80000000-8fffffff memory:90000000-91ffffff ioport:4000(size=128) memory:97080000-970fffff
  *-display
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       logical name: /dev/fb0
       version: 02
       width: 64 bits
       clock: 33MHz
       capabilities: vga_controller bus_master cap_list rom fb
       configuration: depth=32 driver=i915 latency=0 resolution=1920,1080
       resources: irq:354 memory:95000000-95ffffff memory:a0000000-afffffff ioport:6000(size=64) memory:c0000-dffff
WARNING: output may be incomplete or inaccurate, you should run this program as super-user.
Procedures performed
  • install nvidia-driver-520 by apt command
  • after installation, execute nvidia-smi and output is “No devices were found”
I would be very grateful if someone could give me some advice.
Neousys board, see
https://forums.developer.nvidia.com/t/nvidia-driver-problem-rtx3080-12gb-220a/221224/6?u=generix
Thank you for the information!
