NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running
In attempts to download pytorch, I tried downgrading CUDA from 11.2 to 10.0 on Ubuntu 18.04.
This seems to have caused errors in the NVIDIA Driver.
Below are outputs from the following commands
dpkg -l | grep nvidia
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
nvcc -V
Command 'nvcc' not found, but can be installed with:
sudo apt install nvidia-cuda-toolkit
lspci | grep -i nvidia
01:00.0 VGA compatible controller: NVIDIA Corporation GP107GL [Quadro P600] (rev a1)
01:00.1 Audio device: NVIDIA Corporation GP107GL High Definition Audio Controller (rev a1)
I cannot generate the nvidia-bug-report.sh as it outputs
Running nvidia-bug-report.sh...ls: cannot access '/proc/driver/nvidia/./gpus/': No such file or directory
When I checked /proc/driver/, it has no folders.
You installed the full package including drivers, which is too old for the kernel.
  • purge anything nvidia/cuda
  • add the ubuntu graphics ppa [url]https://launchpad.net/~graphics-drivers/+archive/ubuntu/ppa[/url]
  • install the driver from that (sudo apt install nvidia-driver-455)
  • download the cuda .deb
  • add the repo to your system
  • don’t install cuda
  • instead, run sudo apt install cuda-toolkit-10-0
  • set PATH variable if necessary
  • have nvidia-persistenced start on boot and make sure it is continuously running
Thank you for the reponse
I’ve tried to follow your steps with:
sudo apt-get purge nvidia → didn’t remove anything
sudo apt-get purge cuda → removed cuda*
sudo add-apt-repository ppa:graphics-drivers.ppa
sudo apt-get update
They all ran fine without errors
However, when I tried to run:
It comes up with the following error:
Is there a way to fix this?
Thank you!
To remove the driver, try
sudo dpkg -P $(dpkg -l | grep nvidia-driver | awk '{print $2}')
sudo apt autoremove
afterwards, use
dpkg -l |grep nvidia
to check if packages are left and uninstall them manually.
I tried
sudo dpkg -P $(dpkg -l | grep nvidia-driver | awk ‘{print $2}’)
but it came up with
Also, when I try dpkg -l |grep nvidia, I get the same list as shown in my first post. (sorry, seems like I can only add one screenshot per post)
Is there a way to fix this? Also, how do I manually uninstall packages? Do I use sudo apt purge …?
Thank you!
Try
sudo apt remove cuda*
sudo apt remove nvidia*
sudo apt remove libnvidia*
sudo apt remove cuda* didn’t work and outputs the following
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package cuda-repo-ubuntu1804_10.0.130-1_amd64.deb
E: Couldn't find any package by glob 'cuda-repo-ubuntu1804_10.0.130-1_amd64.deb'
E: Couldn't find any package by regex 'cuda-repo-ubuntu1804_10.0.130-1_amd64.deb'
E: Unable to locate package cuda-repo-ubuntu1804_10.0.130-1_amd64.deb.1
E: Couldn't find any package by glob 'cuda-repo-ubuntu1804_10.0.130-1_amd64.deb.1'
E: Couldn't find any package by regex 'cuda-repo-ubuntu1804_10.0.130-1_amd64.deb.1'
E: Unable to locate package cuda-repo-ubuntu1804_10.0.130-1_amd64.deb.2
E: Couldn't find any package by glob 'cuda-repo-ubuntu1804_10.0.130-1_amd64.deb.2'
E: Couldn't find any package by regex 'cuda-repo-ubuntu1804_10.0.130-1_amd64.deb.2'
E: Unable to locate package cuda-repo-ubuntu1804-11-2-local_11.2.0-460.27.04-1_amd64.deb
E: Couldn't find any package by glob 'cuda-repo-ubuntu1804-11-2-local_11.2.0-460.27.04-1_amd64.deb'
E: Couldn't find any package by regex 'cuda-repo-ubuntu1804-11-2-local_11.2.0-460.27.04-1_amd64.deb'
sudo apt remove nvidia* didn’t work and outputted the following
E: Unable to locate package nvidia-bug-report.log.gz
E: Couldn't find any package by glob 'nvidia-bug-report.log.gz'
E: Couldn't find any package by regex 'nvidia-bug-report.log.gz'
E: Unable to locate package nvidia-machine-learning-repo-ubuntu1804_1.0.0-1_amd64.deb
E: Couldn't find any package by glob 'nvidia-machine-learning-repo-ubuntu1804_1.0.0-1_amd64.deb'
E: Couldn't find any package by regex 'nvidia-machine-learning-repo-ubuntu1804_1.0.0-1_amd64.deb'
sudo apt remove libnvidia* seems to have worked and outputted the following
Note, selecting 'libnvidia-encode-418-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-450-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-450-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-440-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-450-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-390' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-418-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-440-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-410' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-415' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-418' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-430' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-435' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-440' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-418-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-450' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-455' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-460' for glob 'libnvidia*'
Note, selecting 'libnvidia-ml1' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-390' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-410' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-415' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-418' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-430' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-435' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-440' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-450' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-455' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-450-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-390' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-410' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-415' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-418' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-430' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-435' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-440' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-450' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-455' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-390' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-440-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-450-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-390' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-410' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-415' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-418' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-430' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-435' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-440' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-450' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-455' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-410' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-415' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-418' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-430' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-435' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-440' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-450' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-455' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-418-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-encode-440-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-450-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-extra' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-390' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-440-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-410' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-415' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-418' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-430' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-435' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-440' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-450' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-455' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-440-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-any' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-440-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-450-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1' for glob 'libnvidia*'
Note, selecting 'libnvidia-cfg1-450-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-390' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-410' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-415' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-418' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-430' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-435' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-440' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-450' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1-455' for glob 'libnvidia*'
Note, selecting 'libnvidia-extra-450-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-418-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-extra-440-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-common' for glob 'libnvidia*'
Note, selecting 'libnvidia-ifr1' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-390' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-410' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-415' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-418' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-430' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-435' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-440' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-450' for glob 'libnvidia*'
Note, selecting 'libnvidia-common-455' for glob 'libnvidia*'
Note, selecting 'libnvidia-compute-418-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-fbc1-418-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-extra-440' for glob 'libnvidia*'
Note, selecting 'libnvidia-extra-450' for glob 'libnvidia*'
Note, selecting 'libnvidia-extra-455' for glob 'libnvidia*'
Note, selecting 'libnvidia-gl-440-server' for glob 'libnvidia*'
Note, selecting 'libnvidia-decode-418-server' for glob 'libnvidia*'
Package 'libnvidia-cfg1-390' is not installed, so not removed
Package 'libnvidia-cfg1-430' is not installed, so not removed
Package 'libnvidia-common-390' is not installed, so not removed
Package 'libnvidia-common-430' is not installed, so not removed
Package 'libnvidia-compute-390' is not installed, so not removed
Package 'libnvidia-compute-430' is not installed, so not removed
Package 'libnvidia-decode-390' is not installed, so not removed
Package 'libnvidia-decode-430' is not installed, so not removed
Package 'libnvidia-encode-390' is not installed, so not removed
Package 'libnvidia-encode-430' is not installed, so not removed
Package 'libnvidia-fbc1-390' is not installed, so not removed
Package 'libnvidia-fbc1-430' is not installed, so not removed
Package 'libnvidia-gl-390' is not installed, so not removed
Package 'libnvidia-gl-430' is not installed, so not removed
Package 'libnvidia-ifr1-390' is not installed, so not removed
Package 'libnvidia-ifr1-430' is not installed, so not removed
Package 'libnvidia-cfg1-440' is not installed, so not removed
Package 'libnvidia-cfg1-450' is not installed, so not removed
Package 'libnvidia-common-440' is not installed, so not removed
Package 'libnvidia-common-450' is not installed, so not removed
Package 'libnvidia-compute-440' is not installed, so not removed
Package 'libnvidia-compute-450' is not installed, so not removed
Package 'libnvidia-decode-440' is not installed, so not removed
Package 'libnvidia-decode-450' is not installed, so not removed
Package 'libnvidia-encode-440' is not installed, so not removed
Package 'libnvidia-encode-450' is not installed, so not removed
Package 'libnvidia-extra-440' is not installed, so not removed
Package 'libnvidia-extra-450' is not installed, so not removed
Package 'libnvidia-fbc1-440' is not installed, so not removed
Package 'libnvidia-fbc1-450' is not installed, so not removed
Package 'libnvidia-gl-440' is not installed, so not removed
Package 'libnvidia-gl-450' is not installed, so not removed
Package 'libnvidia-ifr1-440' is not installed, so not removed
Package 'libnvidia-ifr1-450' is not installed, so not removed
Package 'libnvidia-cfg1-418-server' is not installed, so not removed
Package 'libnvidia-cfg1-440-server' is not installed, so not removed
Package 'libnvidia-cfg1-450-server' is not installed, so not removed
Package 'libnvidia-common-418-server' is not installed, so not removed
Package 'libnvidia-common-440-server' is not installed, so not removed
Package 'libnvidia-common-450-server' is not installed, so not removed
Package 'libnvidia-compute-418-server' is not installed, so not removed
Package 'libnvidia-compute-440-server' is not installed, so not removed
Package 'libnvidia-compute-450-server' is not installed, so not removed
Package 'libnvidia-decode-418-server' is not installed, so not removed
Package 'libnvidia-decode-440-server' is not installed, so not removed
Package 'libnvidia-decode-450-server' is not installed, so not removed
Package 'libnvidia-encode-418-server' is not installed, so not removed
Package 'libnvidia-encode-440-server' is not installed, so not removed
Package 'libnvidia-encode-450-server' is not installed, so not removed
Package 'libnvidia-extra-440-server' is not installed, so not removed
Package 'libnvidia-extra-450-server' is not installed, so not removed
Package 'libnvidia-fbc1-418-server' is not installed, so not removed
Package 'libnvidia-fbc1-440-server' is not installed, so not removed
Package 'libnvidia-fbc1-450-server' is not installed, so not removed
Package 'libnvidia-gl-418-server' is not installed, so not removed
Package 'libnvidia-gl-440-server' is not installed, so not removed
Package 'libnvidia-gl-450-server' is not installed, so not removed
Package 'libnvidia-ifr1-418-server' is not installed, so not removed
Package 'libnvidia-ifr1-440-server' is not installed, so not removed
Package 'libnvidia-ifr1-450-server' is not installed, so not removed
Package 'libnvidia-cfg1-415' is not installed, so not removed
Package 'libnvidia-cfg1-418' is not installed, so not removed
Package 'libnvidia-cfg1-435' is not installed, so not removed
Package 'libnvidia-cfg1-455' is not installed, so not removed
Package 'libnvidia-common-415' is not installed, so not removed
Package 'libnvidia-common-418' is not installed, so not removed
Package 'libnvidia-common-435' is not installed, so not removed
Package 'libnvidia-common-455' is not installed, so not removed
Package 'libnvidia-compute-415' is not installed, so not removed
Package 'libnvidia-compute-418' is not installed, so not removed
Package 'libnvidia-compute-435' is not installed, so not removed
Package 'libnvidia-compute-455' is not installed, so not removed
Package 'libnvidia-decode-415' is not installed, so not removed
Package 'libnvidia-decode-418' is not installed, so not removed
Package 'libnvidia-decode-435' is not installed, so not removed
Package 'libnvidia-decode-455' is not installed, so not removed
Package 'libnvidia-encode-415' is not installed, so not removed
Package 'libnvidia-encode-418' is not installed, so not removed
Package 'libnvidia-encode-435' is not installed, so not removed
Package 'libnvidia-encode-455' is not installed, so not removed
Package 'libnvidia-extra-455' is not installed, so not removed
Package 'libnvidia-fbc1-415' is not installed, so not removed
Package 'libnvidia-fbc1-418' is not installed, so not removed
Package 'libnvidia-fbc1-435' is not installed, so not removed
Package 'libnvidia-fbc1-455' is not installed, so not removed
Package 'libnvidia-gl-415' is not installed, so not removed
Package 'libnvidia-gl-418' is not installed, so not removed
Package 'libnvidia-gl-435' is not installed, so not removed
Package 'libnvidia-gl-455' is not installed, so not removed
Package 'libnvidia-ifr1-415' is not installed, so not removed
Package 'libnvidia-ifr1-418' is not installed, so not removed
Package 'libnvidia-ifr1-435' is not installed, so not removed
Package 'libnvidia-ifr1-455' is not installed, so not removed
Package 'libnvidia-compute-460' is not installed, so not removed
The following packages were automatically installed and are no longer required:
  cuda-libraries-10-0 libxnvctrl0 nvidia-dkms-410 nvidia-kernel-common-410 nvidia-kernel-source-410 nvidia-modprobe nvidia-prime
  nvidia-settings screen-resolution-extra
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
  cuda-10-0 cuda-demo-suite-10-0 cuda-drivers cuda-runtime-10-0 libcuda1-384 libnvidia-cfg1-410 libnvidia-common-410
  libnvidia-compute-410 libnvidia-decode-410 libnvidia-encode-410 libnvidia-fbc1-410 libnvidia-gl-410 libnvidia-ifr1-410
  nvidia-compute-utils-410 nvidia-driver-410 nvidia-headless-410 nvidia-headless-no-dkms-410 nvidia-opencl-icd-384 nvidia-utils-410
  xserver-xorg-video-nvidia-410
0 upgraded, 0 newly installed, 20 to remove and 27 not upgraded.
After this operation, 279 MB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 414327 files and directories currently installed.)
Removing cuda-10-0 (10.0.130-1) ...
Removing cuda-demo-suite-10-0 (10.0.130-1) ...
Removing cuda-runtime-10-0 (10.0.130-1) ...
Removing cuda-drivers (410.48-1) ...
Removing libcuda1-384 (410.48-0ubuntu1) ...
Removing nvidia-driver-410 (410.48-0ubuntu1) ...
Removing xserver-xorg-video-nvidia-410 (410.48-0ubuntu1) ...
Removing libnvidia-cfg1-410:amd64 (410.48-0ubuntu1) ...
Removing libnvidia-ifr1-410:amd64 (410.48-0ubuntu1) ...
Removing libnvidia-gl-410:amd64 (410.48-0ubuntu1) ...
Removing libnvidia-common-410 (410.48-0ubuntu1) ...
Removing libnvidia-encode-410:amd64 (410.48-0ubuntu1) ...
Removing libnvidia-decode-410:amd64 (410.48-0ubuntu1) ...
Removing nvidia-utils-410 (410.48-0ubuntu1) ...
Removing libnvidia-fbc1-410:amd64 (410.48-0ubuntu1) ...
Removing nvidia-opencl-icd-384 (410.48-0ubuntu1) ...
Removing nvidia-headless-410 (410.48-0ubuntu1) ...
Removing nvidia-headless-no-dkms-410 (410.48-0ubuntu1) ...
Removing nvidia-compute-utils-410 (410.48-0ubuntu1) ...
Removing libnvidia-compute-410:amd64 (410.48-0ubuntu1) ...
Processing triggers for man-db (2.8.3-2ubuntu0.1) ...
Processing triggers for libc-bin (2.27-3ubuntu1.4) ...
Should I now run sudo apt autoremove as stated in the code above? Also, are the errors shown from sudo apt remove cuda* and suda apt remove nvidia* ok or do they also require fixing?
Thank you!
Please run the commands in an empty directory, otherwise it will run on the files in that directory.
I tried running it in an empty directory and it seems to have worked.
Just one concern though: when I ran sudo apt remove nvidia* and selected Y to remove, it outputted the following:
(Reading database ... 403381 files and directories currently installed.)
Removing nvidia-dkms-410 (410.48-0ubuntu1) ...
Removing all DKMS Modules
Done.
INFO:Disable nvidia
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/lenovo_thinkpad
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/put_your_quirks_here
DEBUG:Parsing /usr/share/ubuntu-drivers-common/quirks/dell_latitude
update-initramfs: deferring update (trigger activated)
Removing nvidia-kernel-common-410 (410.48-0ubuntu1) ...
Removing nvidia-kernel-source-410 (410.48-0ubuntu1) ...
Removing nvidia-modprobe (410.48-0ubuntu1) ...
Removing nvidia-prime (0.8.8.2) ...
Removing nvidia-settings (410.48-0ubuntu1) ...
Processing triggers for desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
Processing triggers for initramfs-tools (0.130ubuntu3.11) ...
update-initramfs: Generating /boot/initrd.img-5.4.0-58-generic
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8125a-3.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168fp-3.fw for module r8169
cryptsetup: WARNING: failed to detect canonical device of /dev/sda6
cryptsetup: WARNING: could not determine root device from /etc/fstab
cryptsetup: WARNING: Invalid source device /.swapfile
cryptsetup: WARNING: target cryptswap has a random key, skipped
Processing triggers for gnome-menus (3.13.3-11ubuntu1.1) ...
Processing triggers for mime-support (3.60ubuntu1) ...
Are these warnings I should be concerned of?
After running the sudo apt remove commands, I ran dpkg -l |grep nvidia which now shows a much shorter list of
rc  libnvidia-compute-390:amd64                     390.138-0ubuntu0.18.04.1                         amd64        NVIDIA libcompute package
rc  libnvidia-compute-390:i386                      390.138-0ubuntu0.18.04.1                         i386         NVIDIA libcompute package
rc  libnvidia-compute-410:amd64                     410.48-0ubuntu1                                  amd64        NVIDIA libcompute package
rc  libnvidia-compute-460:amd64                     460.27.04-0ubuntu1                               amd64        NVIDIA libcompute package
rc  nvidia-compute-utils-410                        410.48-0ubuntu1                                  amd64        NVIDIA compute utilities
rc  nvidia-dkms-410                                 410.48-0ubuntu1                                  amd64        NVIDIA DKMS package
rc  nvidia-kernel-common-410                        410.48-0ubuntu1                                  amd64        Shared files used with the kernel module
rc  nvidia-prime                                    0.8.8.2                                          all          Tools to enable NVIDIA's Prime
rc  nvidia-settings                                 410.48-0ubuntu1                                  amd64        Tool for configuring the NVIDIA graphics driver
Do I now just remove the remaining packages with sudo apt purge?
e.g. sudo apt purge libnvidia-compute-390:amd64
Thank you!
State ‘rc’ means that the packages are already removed but the config files are left over. You can either ignore them or use ‘purge’ to have a really clean slate.
I tried following your instructions from earlier on but got some errors.
Adding the ubuntu graphics ppa resulted in the following error and warnings.
E: The repository 'file:/var/cuda-repo-10-0-local-10.0.130-410.48  Release' no longer has a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
A similar error also popped up when I tried sudo apt install nvidia-driver-455
After this operation, 1,021 MB of additional disk space will be used.
Get:1 file:/var/cuda-repo-10-0-local-10.0.130-410.48  libxnvctrl0 410.48-0ubuntu1 [19.3 kB]
Err:1 file:/var/cuda-repo-10-0-local-10.0.130-410.48  libxnvctrl0 410.48-0ubuntu1
  File not found - /var/cuda-repo-10-0-local-10.0.130-410.48/./libxnvctrl0_410.48-0ubuntu1_amd64.deb (2: No such file or directory)
Get:2 file:/var/cuda-repo-10-0-local-10.0.130-410.48  nvidia-settings 410.48-0ubuntu1 [963 kB]
Err:2 file:/var/cuda-repo-10-0-local-10.0.130-410.48  nvidia-settings 410.48-0ubuntu1
  File not found - /var/cuda-repo-10-0-local-10.0.130-410.48/./nvidia-settings_410.48-0ubuntu1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-10-0-local-10.0.130-410.48/./libxnvctrl0_410.48-0ubuntu1_amd64.deb  File not found - /var/cuda-repo-10-0-local-10.0.130-410.48/./libxnvctrl0_410.48-0ubuntu1_amd64.deb (2: No such file or directory)
E: Failed to fetch file:/var/cuda-repo-10-0-local-10.0.130-410.48/./nvidia-settings_410.48-0ubuntu1_amd64.deb  File not found - /var/cuda-repo-10-0-local-10.0.130-410.48/./nvidia-settings_410.48-0ubuntu1_amd64.deb (2: No such file or directory)
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Thank you!
The first error is normal, since it’s a local repo, no updates will occur.
The second one is because you added the cuda repo before installing the nvidia-driver from ubuntu repos, I guess.
Remove cuda again, reboot. Then install the driver from ubuntu repos using the “Software&Updates” application, reboot, check if the driver works.
Only then continue with cuda.
I used sudo apt remove cuda* and sudo apt autoremove to remove cuda and rebooted.
I then opened Software&Updates>>Additional Drivers>>Selected “Using NVIDIA driver metapackage from nvidia-driver-455 (proprietary, tested)”>>Selected “Apply Changes”
However, nothing happened and it states “No proprietary drivers are in use”.
[Screenshot of Software&Updates window]
Thank you!
Is the nvidia driver still inactive after reboot? e.g. try running nvidia-smi
nvidia-smi outputs
Command 'nvidia-smi' not found, but can be installed with:
sudo apt install nvidia-340
sudo apt install nvidia-utils-390
That’s a bit odd. Please run
sudo apt update
to renew the package lists. If that doesn’t help, add the graphics drivers ppa and install the driver from that.
sudo apt update also didn’t work and produces the following errors
Adding the graphics driver ppa with sudo add-apt-repository ppa:graphics-drivers.ppa and sudo apt-get update also gave the same error as above.
Please try removing it manually from /etc/apt/sources.list
I’m not too sure what you mean.
What exactly am I supposed to remove and what do you mean by /etc/apt/sources.list
Thank you
Please post the output of
cat /etc/apt/sources.list
