My video drivers are not working. I cannot run cuda samples, with errors
[CUDA Mandelbrot/Julia Set] - Starting…
CUDA error at …/…/common/inc/helper_cuda.h:779 code=100(cudaErrorNoDevice) “cudaGetDeviceCount(&device_count)”
nvidia-smi
yields
NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
uname -a
Linux mazza-GE62VR-6RF 5.4.0-94-generic #106-Ubuntu SMP Thu Jan 6 23:58:14 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
gcc --version
gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0
lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 20.04.3 LTS
Release: 20.04
Codename: focal
nvidia-settings
ERROR: NVIDIA driver is not loaded
ERROR: Unable to load info from any available system
Oh goodness! You made an installer mess!
First: do not use the .run file installer, if there is not a good reason to. It even advises you not to use itself before installing!
Second: do not mix distro and .run file installations. Always remove either of them before using the other!
Third: If using the runfile installer, make sure to not use it, when X is still running!
Ok, lets try to clean up…
run sudo apt purge 'libnvidia*' 'nvidia*'
start the .run file installer again with the --uninstall parameter.
look for files blacklisting the nvidia driver: grep -r -e "blacklist.*nvidia$" /etc/modprobe.d /lib/modprobe.d - and delete them if found (sidenote: nvidiafb needs to be blacklisted).
run sudo apt install nvidia-driver-470 (or -495 as you wish) - watch the output closely, to look for errors.
check the dkms for success: dkms status|grep nvidia - should say “installed”.
run sudo prime-select nvidia or sudo prime-select on-demand (if you only want to render certain applications on the nvidia gpu (Chapter 34. PRIME Render Offload)
Also helped, because I could not find out which packages to delete (I could not delete nvidia-smi even after purging all my drivers through with apt remove --purge nvidia)
I really did a mess with my drivers but it now works, thanks!
