Hi
First off - i am quite a new Linux user, so please be gentle ;-)
I ran into a problem, after installing a new Ubuntu server 24.04.1 LTS (on a proxmox vm) and installing the proprietary 550.127.08 driver on my Lenovo Server ST550, the " NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running"
the card i recognized and the driver is also - but still no luck…
I have tried reinstalling the driver, disabling SecureBoot, rebuilding the kernel module
sudo dkms remove nvidia/550.127.08 --all
sudo dkms install nvidia/550.127.08
and the system returns this :
lspci | grep -i nvidia
06:10.0 3D controller: NVIDIA Corporation GP102GL [Tesla P40] (rev a1)
dpkg -l | grep -i nvidia
ii libnvidia-cfg1-550:amd64 550.127.08-0ubuntu1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-550 550.127.08-0ubuntu1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-550:amd64 550.127.08-0ubuntu1 amd64 NVIDIA libcompute package
ii libnvidia-container-tools 1.17.3-1 amd64 NVIDIA container runtime library (command-line tools)
ii libnvidia-container1:amd64 1.17.3-1 amd64 NVIDIA container runtime library
ii libnvidia-decode-550:amd64 550.127.08-0ubuntu1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-egl-wayland1:amd64 1:1.1.13-1build1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-encode-550:amd64 550.127.08-0ubuntu1 amd64 NVENC Video Encoding runtime library
ii libnvidia-extra-550:amd64 550.127.08-0ubuntu1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-550:amd64 550.127.08-0ubuntu1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-550:amd64 550.127.08-0ubuntu1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii nvidia-compute-utils-550 550.127.08-0ubuntu1 amd64 NVIDIA compute utilities
ii nvidia-container-toolkit 1.17.3-1 amd64 NVIDIA Container toolkit
ii nvidia-container-toolkit-base 1.17.3-1 amd64 NVIDIA Container Toolkit Base
ii nvidia-dkms-550 550.127.08-0ubuntu1 amd64 NVIDIA DKMS package
ii nvidia-driver-550 550.127.08-0ubuntu1 amd64 NVIDIA driver metapackage
ii nvidia-firmware-550-550.120 550.120-0ubuntu0.24.04.1 amd64 Firmware files used by the kernel module
ii nvidia-firmware-550-550.127.08 550.127.08-0ubuntu1 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-550 550.127.08-0ubuntu1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-550 550.127.08-0ubuntu1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.2 all Tools to enable NVIDIA's Prime
ii nvidia-settings 565.57.01-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-550 550.127.08-0ubuntu1 amd64 NVIDIA driver support binaries
ii nvtop 3.0.2-1 amd64 Interactive NVIDIA GPU process monitor
ii screen-resolution-extra 0.18.3 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-550 550.127.08-0ubuntu1 amd64 NVIDIA binary Xorg driver
sudo modprobe nvidia
modprobe: ERROR: could not insert 'nvidia': Key was rejected by service
I have attached the nvidia bug report
nvidia-bug-report.log.gz (83.7 KB)
Any suggestions would be appreciated
