Run
sudo mv /usr/lib/systemd/system/nvidia-persistenced.service /usr/lib/systemd/system/nvidia-persistenced.service.disabled
I had same issue and it will may fixes your issue
Run
560 - Nvidia-smi memory leak .. temporary fix found here | 4 | 622 | May 30, 2025 | |
Nvidia-smi Memory Leak with 570.133.07 and Ubuntu 25.04 | 8 | 787 | September 9, 2025 | |
Huge RAM usage when using nvidia-smi | 3 | 433 | February 3, 2025 | |
`nvidia-smi` Performance degredation | 5 | 504 | August 14, 2024 | |
Nvidia-smi triggers OOM and is killed by kernel on Ubuntu 25.04 with driver 570.133.07 | 1 | 237 | May 25, 2025 | |
Cannot nvidia-smi Geforce 1070 anymore suddenly. | 9 | 1675 | October 12, 2021 | |
384.90 on Centos7.3 would sometimes block CPU | 6 | 1298 | March 8, 2018 | |
Power9 - nvidia-smi shows "unknown error" in memory column | 35 | 10352 | October 14, 2021 | |
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running. | 125 | 85712 | August 5, 2024 | |
GeForce RTX 2080 ERR! show in nvidia-smi | 33 | 5025 | April 12, 2019 |
