Nvidia vpi image format conversion
The vpiSubmitBoxFilter encountered an error while processing the image:
terminate called after throwing an instance of ‘std::runtime_error’
what(): VPI_ERROR_INVALID_IMAGE_FORMAT: Source image format not supported
I get the VPIImageFormat of the image, how should I convert the unsupported Format to the Format I want
VPIImageFormat type;
CHECK_STATUS(vpiImageGetFormat(input, &type));
VPIImage output;
CHECK_STATUS(vpiImageCreate(w, h, type, 0, &output));
CHECK_STATUS(vpiSubmitBoxFilter(stream, VPI_BACKEND_CUDA, input, output, 5, 5, VPI_BORDER_ZERO));
I used the following interface to output the Format of the current image, the Format of the image is: VPI_IMAGE_FORMAT_BGR8
std::cout << vpiImageFormatGetName(type) << std::endl;
Based on the document below, only gray images are supported by the BoxFilter.
https://docs.nvidia.com/vpi/group__VPI__BoxFilter.html#ga6d75b4b9c56195d9b4032fe291626c47
Please check the below sample for the demonstration of the BoxFilter with ColorCoverter.
/opt/nvidia/vpi2/samples/tutorial_blur
