In OpencV, data in memory is usually decoded this way:
// get raw data in memory
std::vector<uchar> vec_data_encode;
// decode by opencv
cv::Mat mat_decode = cv::imdecode(vec_data_encode, cv::IMREAD_COLOR);
cv::imwrite("./mat_decode.png", mat_decode);
How to implement cv::imdecode with VPI 2.0.14?
Can vpiSubmitConvertImageFormat do this?
Your issue looks to be posted in the wrong category, you posted in the Software and Drivers section of Networking. Can you please provide more information on your issue, and I can move it to the proper forum.
My hardware is Jetson AGX Orin, and I want to replace part of OpenCV’s interface with VPI ( Vision Programming Interface, a computer vision library by NVIDIA ).
I have moved it to Computer Vision & Image Processing.
vpiSubmitConvertImageFormat converts between vpi formats.
In all the examples they create a cv::Mat and then convert it to a VPIImage with vpiImageCreateOpenCVMatWrapper/vpiImageSetWrappedOpenCVMat
There is a function that takes a pointer (vpiImageCreate) but I’m not sure if it can take just any pointer.
I don’t think cv::imdecode can be implemented in VPI.
I’m currently trying jetson_multimedia_api.
I found jpeg_encode sample in jpeg_encode sample, and can generate image use command: $ ./jpeg_encode ../../data/Picture/nvidia-logo.yuv 1920 1080 test.jpg
But how to convert std::vector<uchar> to *.yuv ? Do you have any idea?
