**• Hardware Platform (Jetson / GPU) : dGPU
**• DeepStream Version : 6.1.1
**• JetPack Version (valid for Jetson only) : None
**• TensorRT Version : 8.4.1
**• NVIDIA GPU Driver Version (valid for GPU only) : 515.65.01
**• Issue Type( questions, new requirements, bugs) : questions
**• How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) : None
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) : None
DeepStream 6.1.1 Release Note states that
The following new features are supported in this DeepStream SDK release:
Enhance nvinferserver to work with Preprocess plugin
However, I could not find example codes nor documentation.
Does nvinferserver work with nvdspreprocess in DeepStream 6.1.1?
