**• Hardware Platform (Jetson / GPU)GPU
**• DeepStream Version 5.1
• TensorRT Version does not matter
• NVIDIA GPU Driver Version (valid for GPU only) does not matter
**• Issue Type( questions, new requirements, bugs)questions
• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description) dsexample
Hi everyone,
I am building on top of deepstream-test5 app with dsanalytics. I would like to add some OpenCV preprocessing on all streams on the whole frame before inference to reduce some artifacts and improve detection. I believe I could use dsexample in full frame mode for that but I do not understand how to ensure that dsexample is run before everything else. I have seen this post: How to insert dsexample as a preprocessor? but it’s not quite clear to me from there what are the right steps to change the order from post inference to before inference and if it should be added as common_elements or not.
Looking forward to hear from you
Kind regards,
D
