Realized that preprocess was not added into pipeline in main.
So preprocess was added using gst_element_factory_make
preprocess = gst_element_factory_make("nvdspreprocess", "preprocess-plugin");
nvds_parse_preprocess(preprocess, argv[1], "secondary-preprocess");
gst_bin_add_many(GST_BIN(pipeline), pgie, tracker, preprocess, nvtile,
nvvidconv, nvosd, sink, nvdslogger, NULL);
// Link elements
if (!gst_element_link_many(streammux, pgie, tracker, preprocess, nvdslogger, nvtile, nvvidconv, nvosd, sink, NULL)) {
g_printerr ("Elements could not be linked. Exiting.\n");
return -1;
But I have what(): bad_function_call, when the app runs.
The whole errors are as follows.
WARNING: Overriding infer-config batch-size (0) with number of sources (20)
sink_type:3, enc_type:0
Now playing!
terminate called after throwing an instance of 'std::bad_function_call'
Aborted (core dumped)
The whole main() loop is as follows.
int main(int argc, char *argv[])
guint num_sources = 0;
GMainLoop *loop = NULL;
GstCaps *caps = NULL;
GstElement *streammux = NULL, *pgie = NULL, *preprocess = NULL;
GstElement *nvvidconv = NULL, *nvtile = NULL, *nvosd = NULL, *tracker = NULL, *nvdslogger = NULL;
GstElement *sink = NULL;
DsSourceBinStruct source_struct[128];
GstBus *bus = NULL;
guint bus_watch_id;
gboolean useDisplay = FALSE;
gboolean useFakeSink = FALSE;
gboolean useFileSink = FALSE;
guint tiler_rows, tiler_columns;
GstPad *sinkpad, *srcpad;
gchar pad_name_sink[16] = "sink_0";
gchar pad_name_src[16] = "src";
bool isStreaming=false;
GList* g_list = NULL;
GList* iterator = NULL;
bool isH264 = true;
gchar *filepath = NULL;
int current_device = -1;
cudaGetDevice(¤t_device);
struct cudaDeviceProp prop;
cudaGetDeviceProperties(&prop, current_device);
/* Standard GStreamer initialization */
// signal(SIGINT, sigintHandler);
gst_init(&argc, &argv);
loop = g_main_loop_new(NULL, FALSE);
_intr_setup ();
g_timeout_add (400, check_for_interrupt, NULL);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new("deepstream_pose_classfication_app");
if (!pipeline) {
g_printerr ("Pipeline could not be created. Exiting.\n");
return -1;
/* we add a message handler */
bus = gst_pipeline_get_bus(GST_PIPELINE(pipeline));
bus_watch_id = gst_bus_add_watch(bus, bus_call, loop);
gst_object_unref(bus);
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make ("nvstreammux", "streammux-pgie");
if (!streammux) {
g_printerr ("PGIE streammux could not be created. Exiting.\n");
return -1;
gst_bin_add(GST_BIN(pipeline), streammux);
parse_streammux_width_height_yaml(&_image_width, &_image_height, argv[1]);
g_print("width %d hight %d\n", _image_width, _image_height);
if (NVDS_YAML_PARSER_SUCCESS != nvds_parse_source_list(&g_list, argv[1], "source-list")) {
g_printerr ("No source is found. Exiting.\n");
return -1;
for (iterator = g_list, num_sources=0; iterator; iterator = iterator->next,num_sources++) {
/* Source element for reading from the file */
source_struct[num_sources].index = num_sources;
if (g_strrstr ((gchar *)iterator->data, "rtsp://") ||
g_strrstr ((gchar *)iterator->data, "v4l2://") ||
g_strrstr ((gchar *)iterator->data, "http://") ||
g_strrstr ((gchar *)iterator->data, "rtmp://")) {
isStreaming = true;
} else {
isStreaming = false;
g_print("video %s\n", (gchar *)iterator->data);
if (!create_source_bin (&(source_struct[num_sources]), (gchar *)iterator->data))
g_printerr ("Source bin could not be created. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), source_struct[num_sources].source_bin);
g_snprintf (pad_name_sink, 64, "sink_%d", num_sources);
sinkpad = gst_element_get_request_pad (streammux, pad_name_sink);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (source_struct[num_sources].source_bin,
pad_name_src);
if (!srcpad) {
g_printerr ("Decoder request src pad failed. Exiting.\n");
return -1;
GstPadLinkReturn ret = gst_pad_link (srcpad, sinkpad);
if ( ret != GST_PAD_LINK_OK) {
g_printerr ("Failed to link decoder to stream muxer. Exiting. %d\n",ret);
return -1;
gst_object_unref (sinkpad);
gst_object_unref (srcpad);
nvds_parse_streammux(streammux, argv[1], "streammux");
if (isStreaming)
g_object_set (G_OBJECT (streammux), "live-source", true, NULL);
g_object_set (G_OBJECT (streammux), "batch-size", num_sources, NULL);
/* Use nvinfer to run inferencing on decoder's output,
* behaviour of inferencing is set through config file */
NvDsGieType pgie_type = NVDS_GIE_PLUGIN_INFER;
RETURN_ON_PARSER_ERROR(nvds_parse_gie_type(&pgie_type, argv[1], "primary-gie"));
if (pgie_type == NVDS_GIE_PLUGIN_INFER_SERVER) {
pgie = gst_element_factory_make("nvinferserver", "primary-nvinference-engine");
} else {
pgie = gst_element_factory_make("nvinfer", "primary-nvinference-engine");
if (!pgie) {
g_printerr ("PGIE element could not be created. Exiting.\n");
return -1;
nvds_parse_gie (pgie, argv[1], "primary-gie");
/* preprocess */
/* Override the batch-size set in the config file with the number of sources. */
guint pgie_batch_size = 0;
g_object_get(G_OBJECT(pgie), "batch-size", &pgie_batch_size, NULL);
if (pgie_batch_size != num_sources) {
g_printerr
("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
pgie_batch_size, num_sources);
g_object_set(G_OBJECT(pgie), "batch-size", num_sources, NULL);
//---Set pgie properties---
/* We need to have a tracker to track the identified objects */
tracker = gst_element_factory_make ("nvtracker", "tracker");
if (!tracker) {
g_printerr ("Nvtracker could not be created. Exiting.\n");
return -1;
nvds_parse_tracker(tracker, argv[1], "tracker");
nvdslogger = gst_element_factory_make ("nvdslogger", "nvdslogger");
if (!nvdslogger) {
g_printerr ("Nvdslogger could not be created. Exiting.\n");
return -1;
g_object_set (G_OBJECT(nvdslogger), "fps-measurement-interval-sec",
1, NULL);
/* Lets add probe to get informed of the meta data generated, we add probe to
* the sink pad of the osd element, since by that time, the buffer would have
* had got all the metadata. */
GstPad* pgie_src_pad = gst_element_get_static_pad(tracker, "src");
if (!pgie_src_pad)
g_printerr ("Unable to get src pad for pgie\n");
else
gst_pad_add_probe(pgie_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
pgie_src_pad_buffer_probe, NULL, NULL);
gst_object_unref (pgie_src_pad);
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make("nvvideoconvert", "nvvideo-converter");
if (!nvvidconv) {
g_printerr ("nvvidconv could not be created. Exiting.\n");
return -1;
gchar *string1 = NULL;
asprintf (&string1, "video/x-raw(memory:NVMM),width=%d,height=%d",
//---Manipulate image size so that PGIE bbox is large enough---
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
if (!nvosd) {
g_printerr ("Nvdsosd could not be created. Exiting.\n");
return -1;
nvtile = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
tiler_rows = (guint) sqrt (num_sources);
tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
g_object_set (G_OBJECT (nvtile), "rows", tiler_rows, "columns",
tiler_columns, "width", 1280, "height", 720, NULL);
GstPad* osd_sink_pad = gst_element_get_static_pad(nvosd, "sink");
if (!osd_sink_pad)
g_print("Unable to get sink pad\n");
else
gst_pad_add_probe(osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
osd_sink_pad_buffer_probe, NULL, NULL);
gst_object_unref(osd_sink_pad);
/* Set output file location */
int sink_type = 0;
parse_sink_type_yaml(&sink_type, argv[1]);
int enc_type = 0;
parse_sink_enc_type_yaml(&enc_type, argv[1]);
g_print("sink_type:%d, enc_type:%d\n", sink_type, enc_type);
if(sink_type == 1) {
sink = gst_element_factory_make("nvvideoencfilesinkbin", "nv-filesink");
if (!sink) {
g_printerr ("Filesink could not be created. Exiting.\n");
return -1;
g_object_set(G_OBJECT(sink), "output-file", "out.mp4", NULL);
g_object_set(G_OBJECT(sink), "bitrate", 4000000, NULL);
//g_object_set(G_OBJECT(sink), "profile", 3, NULL);
g_object_set(G_OBJECT(sink), "codec", 1, NULL);//hevc
// g_object_set(G_OBJECT(sink), "control-rate", 0, NULL);//hevc
g_object_set(G_OBJECT(sink), "enc-type", enc_type, NULL);
} else if(sink_type == 2) {
sink = gst_element_factory_make("nvrtspoutsinkbin", "nv-rtspsink");
if (!sink) {
return -1;
} else if(sink_type == 3) {
if (prop.integrated) {
sink = gst_element_factory_make("nv3dsink", "nv-sink");
} else {
#ifdef __aarch64__
#else
sink = gst_element_factory_make("nveglglessink", "nv-sink");
#endif
} else {
sink = gst_element_factory_make("fakesink", "nv-fakesink");
/* Add all elements to the pipeline */
// streammux has been added into pipeline already.
// Link elements
return -1;
/* Set the pipeline to "playing" state */
g_print("Now playing!\n");
gst_element_set_state(pipeline, GST_STATE_PLAYING);
GST_DEBUG_BIN_TO_DOT_FILE((GstBin*)pipeline, GST_DEBUG_GRAPH_SHOW_ALL, "pipeline");
/* Wait till pipeline encounters an error or EOS */
g_print("Running...\n");
g_main_loop_run(loop);
/* Out of the main loop, clean up nicely */
g_print("Returned, stopping playback\n");
gst_element_set_state(pipeline, GST_STATE_NULL);
g_print("Deleting pipeline\n");
gst_object_unref(GST_OBJECT(pipeline));
g_source_remove(bus_watch_id);
g_main_loop_unref(loop);
return 0;
