My test pipeline is
gst-launch-1.0 videotestsrc ! nvjpegenc ! nvjpegdec ! nvoverlaysink
On stock R32.3.1 this runs with a CPU load of 17.8%.
However it slowly leaks memory, a few kilobytes per minute.
I tried the patched library from https://devtalk.nvidia.com/default/topic/1069296/jetson-nano/streaming-using-jpegenc-halts-after-a-short-delay/post/5419826/#5419826
The above pipeline now fails
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
NvMapMemHandleCreate: error 22
Pipeline is PREROLLED ...
NvxBaseWorkerFunction[2575] comp OMX.Nvidia.std.iv_renderer.overlay.yuv420 Error -2147479552
Setting pipeline to PLAYING ...
New clock: GstSystemClock
ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0:
streaming stopped, reason error (-5)
Execution ended after 0:00:00.000497747
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
As does a pipeline with NVMM specified.
This is odd given that videotestsrc is the only non Nvidia plugin.
gst-launch-1.0 videotestsrc ! nvjpegenc ! nvjpegdec ! 'video/x-raw(memory:NVMM)' ! nvoverlaysink
Execution ended after 0:00:00.000431382
This pipeline still slowly leaks memory and has increased CPU load at 23.7%
gst-launch-1.0 videotestsrc ! nvjpegenc ! nvjpegdec ! video/x-raw ! nvoverlaysink
Attempting to convert videotestsrc fails with sigsegv
gst-launch-1.0 videotestsrc ! nvvidconv ! nvjpegenc ! nvjpegdec ! nvoverlaysink
Caught SIGSEGV
#0 0x0000007f98125048 in __GI___poll (fds=0x5574a53550, nfds=548013286000, timeout=<optimized out>) at ../sysdeps/unix/sysv/linux/poll.c:41
#1 0x0000007f98231e40 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x0000005574926330 in ()
Spinning. Please run 'gdb gst-launch-1.0 13303' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
My original post was
https://devtalk.nvidia.com/default/topic/1066646/jetson-tx2/tx2-sigsegv-with-patched-libnvjpeg-so/post/5427488/
