NVJPEGDEC gives segmentation fault (core dumped) on MJPEG http stream Jetpack 5.1 L4T 35.2.1
I have used the nvjpegdec element on xavier nx (Jetpack 4.6 - L4T 32.6.1).
I am using a gstreamer pipeline to visualize a camera in Qt
Xavier nx pipeline to visualize MJPEG http stream:
souphttpsrc location=http://192.168.1.2:8084/mjpeg  is-live=1 timeout=3 do-timestamp=true ! multipartdemux ! nvjpegdec ! qtvideosink sync=0
To use gst-launch-1.0 xvimagesink can be used instead of qtvideosink
I have never had a problem with this pipeline and it works perfectly
I have upgraded from Xavier NX to Orin NX. The Orin NX has jetpack 5.1 and L4t 35.2.1
When I use the pipeline I get a segmentation fault.
This segmentation fault is not always occurring, and I have not been able to pinpoint why it is occurring.
When I change the nvjpegdec to jpegdec (base gstreamer jpeg decoding). The segmentation fault never occurs
souphttpsrc location=http://192.168.1.2:8084/mjpeg  is-live=1 timeout=3 do-timestamp=true ! multipartdemux ! jpegdec ! qtvideosink sync=0
Furthermore I have also tested the nvv4l2decoder:
This pipeline also works perfectly and renders the camera.
souphttpsrc location=http://192.168.1.2:8084/mjpeg  is-live=1 timeout=3 do-timestamp=true  ! multipartdemux ! jpegparse !   nvv4l2decoder mjpeg=1  ! nvvidconv !   qtvideosink sync=0
What is the error with nvjpegdec? I would love to keep using nvjpegdec instead of nvv4l2decoder because the nvv4l2decoder has a somewhat slower startup time.
Please try the pipeline and see if it works:
$ souphttpsrc location=http://192.168.1.2:8084/mjpeg  is-live=1 timeout=3 do-timestamp=true ! multipartdemux ! nvjpegdec ! video/x-raw ! videoconvert ! xvimagesink sync=0
$ souphttpsrc location=http://192.168.1.2:8084/mjpeg  is-live=1 timeout=3 do-timestamp=true ! multipartdemux ! nvjpegdec ! video/x-raw ! videoconvert ! qtvideosink sync=0
Hello DaneLLL,
I have tested these but NVjpegdec keeps giving segmentation errors at random times.
When using Nvv4l2decoder this does not happen.
Is there a patch for NVJPEGDEC?
Thanks in advance!
We also support MJPEG decoding in nvv4l2decoder. Please try:
... ! nvv4l2decoder mjpeg=1 ! ...
And would be great if you can upgrade to latest Jetpack 5.1.2
nvv4l2decoder works perfect but has a slow load time.
I will upgrade to jetpack 5.1.2 and repost my findings regarding the NVJPEGDEC gstreamer plugin.
This can take a few weeks.
Please note there is a known issue on Jetpack 5.1.2:
Issues with nvjpegdec on live HTTP streams - #3 by DaneLLL
We would suggest use nvv4l2decoder for MJPEG decoding, and wait for next Jetpack 5.1.3.
