NVMe enumeration order
Orin Nano,R36.4.3(Jetpack6.2)环境,在自制载板上,PCIe的C1 和C7,各自连接到一个NVMe硬盘接口。两个NVMe位置,都能正常启动系统。
因为硬件结构上,将C7定义为系统盘,C1为数据盘。导致了系统盘符会有发生变化的情况,如下:
在单接系统盘时,C7→nvme0,
当接两个硬盘时,C1–>nvme0,C7–>nvme1
我想更改枚举顺序,让C7排到C1前面枚举,从而能固定编号为nvme0,请问应该怎样设置?
We do not provide such a setting.
Please flash the system using the specific NVMe device number.
For example, replace nvme1n1p1 with nvme0n1p1 if that is your system disk.
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --external-device nvme1n1p1 \
  -c tools/kernel_flash/flash_l4t_t234_nvme.xml \
  --showlogs --network usb0 jetson-agx-orin-devkit external
I got it , thanks for your reply.
