Nvosd_draw_rectangles do not draw when NvOSD_RectParams.border_width = 1
Hi guys
I found interesting case when border_width = 1 rectangle do not appear, and when I set border_width = 2 rectangle appear but it’s actually has border_width = 1
maybe nvosd has hidden limits for border_width
my setup
aarch64 NVIDIA Jetson Nano Developer Kit
R32 (release), REVISION: 7.6, GCID: 38171779, BOARD: t210ref, EABI: aarch64, DATE: Tue Nov 5 07:46:14 UTC 2024
• DeepStream Version
• TensorRT Version
which DeepStream version are you testing? Using the test code 1.c (1.9 KB), I can’t reproduce this issue. could you share a simplified code to reproduce the issue? Thanks!
Hm I can’t found deepstream library on my Nano
also I see NvBufSurface in your code and assuming you use much newer version and possible this bug fixed in newer version
The code I shared is DeepStream sample code. Did not you install DeepStream? aren’t you testing DeepStream? How did you test Nvosd_draw_rectangles?
I am using nvosd.h from jetson_multimedia_api
We will not have further Jetpack 4 release:
Announcing End of Life for NVIDIA JetPack™ 4 with the release of JetPack 4.6.6
Please set border_width = 2 as a solution.
