I’m triyng to plot 20 rectangles in deepstream_app_main.c in function overlay_graphics and i received this error: $libnvosd (209):(ERROR) : Unsupported border width
Please,could you explain how draw rectangles dynamically?
HI
After change your code a little and test with sample sources/apps/sample_apps/deepstream-infer-tensor-meta-test/deepstream_infer_tensor_meta_test.cpp:: osd_sink_pad_buffer_probe, it run well, you can change yours accordingly
with deepstream-app
I has modified other files, but i tested with original files and application crash again.
The application works fine when the number of rectangles is less than 16!
I has tested so much and i think this is a bug!
HI
Sorry for a late reply, User can draw maximum upto 16 rectangles for 1 “display_meta”. If user wants to draw more than 16 then needs to acquire additional “display_meta” and add remaining rectangles to it.
