NVRM: This PCI I/O region assigned to your NVIDIA device is invalid: BAR1 is 0M @ 0x0 (PCI:0000:0b.0)
Problem statement
I’m running into a problem getting a P40 running while assigned to an Ubuntu 22 LTS VM via direct passthrough. At boot the system log is spammed by the message in the title, repeating roughly every 300msec like this:
NVRM: BAR1 is 0M @ 0x0 (PCI:0000:0b.0)
On this same host I have a Windows 11 VM which is able to passthrough the device as expected and everything works.
Host system details
  • DL380p Gen8, 384GB RAM installed
  • GPU enablement kit installed for 16x PCIe risers/power/etc
  • Tesla P40, 24GB VRAM
  • PCI Express 64-Bit BAR Support enabled in hidden BIOS menu
  • SR-IOV enabled in BIOS
  • Host is running ESXI 8.0 U1
  • System boots and runs off of internal graphics
Guest VM details
  • Installed guest via “ubuntu-22.04.2-live-server-amd64”, no desktop
  • 64GB RAM assigned to VM and reserved
  • As this card is 16GB or greater, I’ve added the following Advanced Configuration settings to the ESXi VM
    • pciPassthru.64bitMMIOSizeGB = 64
    • pciPassthru.use64bitMMIO = TRUE
  • Tested with and without GRUB kernel command pci=realloc, no difference.
Guest VM driver install process
sudo apt-get install build-essential manpages-dev
sudo apt install nvidia-driver-525
sudo reboot now
Guest VM PCI
Card is visible to the guest
lspci | grep NVIDIA
0b:00.0 3D controller: NVIDIA Corporation GP102GL [Tesla P40] (rev a1)
Guest VM logs
nvidia-bug-report.log.gz (205.5 KB)
If anyone has any ideas as how I can make this work under a Linux VM I’d really appreciate it. Given that it works with a Windows VM I suspect that I must be relatively close but have beating my head against this for a week now and figured I’d see if anyone else had any ideas.
Resolved! This post made for a good rubber ducky :D
As noted above, I had deployed the Windows test system initially and it worked once provided with the couple Advanced Config options needed for large RAM cards. I did the same for Linux and it didn’t work, but I just figured out why: VMware defaults to UEIF boot for Win 10+ VMs, but defaults to BIOS boot when selecting Ubuntu Linux.
I re-deployed the Ubuntu machine with the two advanced settings and UEFI boot enabled, and now everything is working like it should.
$ nvidia-smi
Mon Jul 17 14:10:44 2023
| NVIDIA-SMI 525.125.06   Driver Version: 525.125.06   CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  Tesla P40           Off  | 00000000:0B:00.0 Off |                  Off |
| N/A   40C    P8    11W / 250W |      0MiB / 24576MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
