Is it possible to prototype NVSHMEM solutions using a GTX3090 ? I have been testing installations but I get a problem when trying to use nvshmem_malloc. Is it recommended to use MPI + OpenShmem instead ? Do you have any specific tutorial to understand the problem ?
Error as seen:
WARN: GDRCopy open call failed, falling back to not using GDRCopy
src/mem/mem.cpp:416: non-zero status: 101 cuMemCreate failed
src/team/team_internal.cu:287: NULL value nvshmemi_psync_pool allocation failed
src/init/init.cu:762: non-zero status: 2 team setup failed
src/init/init.cu:796: non-zero status: 7 nvshmemi_common_init failed …src/init/init_device.cu:nvshmemi_check_state_and_init:44: nvshmem initialization failed, exiting
src/util/cs.cpp:21: non-zero status: 16: No such file or directory, exiting… mutex destroy failed
