Nvstreammux: Successfully handled EOS for source_id=15
GPU
• DeepStream Version
6.3.0
• TensorRT Version
8.5
535.54.03
questions
I was using the deepstream program built in Python to simultaneously read 20 channels of monitoring RTSP key frames. It ran normally for more than ten hours, and then I found that the program was abnormal. The log output is as follows. What is the cause of this?
nvstreammux: Successfully handled EOS for source_id=15
2023-11-30 02:12:52 - INFO - image_put_path: area_statistics--/stream_15/frame_3971.jpg
nvstreammux: Successfully handled EOS for source_id=9
2023-11-30 02:12:52 - INFO - image_put_path: area_statistics--/stream_9/frame_3970.jpg
nvstreammux: Successfully handled EOS for source_id=19
2023-11-30 02:12:52 - INFO - image_put_path: area_statistics--/stream_19/frame_3968.jpg
nvstreammux: Successfully handled EOS for source_id=6
nvstreammux: Successfully handled EOS for source_id=14
2023-11-30 02:12:52 - INFO - image_put_path: area_statistics--/stream_6/frame_3883.jpg
2023-11-30 02:12:52 - INFO - image_put_path: area_statistics--/stream_14/frame_3974.jpg
nvstreammux: Successfully handled EOS for source_id=11
2023-11-30 02:12:53 - INFO - image_put_path: area_statistics--/stream_11/frame_3706.jpg
nvstreammux: Successfully handled EOS for source_id=10
2023-11-30 02:12:54 - INFO - image_put_path: area_statistics--/stream_10/frame_3832.jpg
nvstreammux: Successfully handled EOS for source_id=3
2023-11-30 02:12:56 - INFO - image_put_path: area_statistics--/stream_3/frame_3971.jpg
2023-11-30 02:12:56 - INFO - End-of-stream
2023-11-30 02:12:56 - INFO - Exiting app
To add, I just discovered that every period of time, or a few minutes or ten minutes, there will be a nvstreammux: Successfully handled EOS for source_id=xxx situation
Is this situation related to the camera or the network? Both the server and the camera belong to the intranet
Does anyone know the reason for this?
EOS is sent by the RTSP server side. Please check with your RTSP server first.
OK, thanks for your reply
Can you please give me some troubleshooting directions? Because I don’t know anything about rtsp server
The GStreamer rtspsrc follows the RFC 2326: Real Time Streaming Protocol (RTSP) (rfc-editor.org) standard.
Thanks a million
