**• Hardware Platform ----> GPU
**• DeepStream Version -----> 6.4/7
**• TensorRT Version —> >8.5 • NVIDIA GPU Driver Version (valid for GPU only) ----> 545
For Nvurisrcbin I am experimenting with record feature I show same some topic is created already. Some topic is saying till now it’s not usable. I want to know smart recording feature is usable through python ?
start
Exception in thread Thread-1:
File “/usr/lib/python3.10/threading.py”, line 1016, in _bootstrap_inner
self.run()
File “/usr/lib/python3.10/threading.py”, line 1378, in run
self.function(*self.args, **self.kwargs)
File “/opt/nvidia/deepstream/deepstream-6.4/deepstream_python_apps/apps/deepstream-test3/deepstream_smart_record.py”, line 68, in action
ele.emit(‘start-sr’, a, 2, 7, None)
TypeError: could not convert type int to gpointer required for parameter 0 smart_record.py.txt (17.5 KB)
I am doing the same thing , but I was not using gpointer_bind.dff , My question is How I can execute the bindings , which path I need to add the code ! How I can make bindings or How I can use
m.def(“alloc_buffer1”,
[](size_t size) {
return (gpointer) g_malloc0(size);
"size"_a,
py::return_value_policy::reference,
pydsdoc::methodsDoc::alloc_buffer1);
function !
If you can provide me proper details that would be great !
Sorry, I don’t understand what you mean. Add cpp patch (gpointer_bind.dff), then rebuild pyds, add python patch (test.py.diff), isn’t that enough? This FAQ has all the information.
I tried what you said I added " bindings/docstrings/functionsdoc.h" I added the code
and “/bindings/src/bindfunctions.cpp” also I added the code and then a create the bindings.
Then also run deepstream-test3
I added action function as you added.
But also “AttributeError: module ‘pyds’ has no attribute ‘alloc_buffer1’. Did you mean: ‘alloc_buffer’?”
I am attaching my pyds bindings can you check once !
And Can you share your python bindings where you show “nvurisrcbin” with smart record is working.
Then I can check it that works for me or not !
I have deepstream version 7.0 pyds_file.zip (1.0 MB)
There is no problem with the code, please install pyds correctly,I tested it on DS-7.0, your code is based on DS-6.4, they are the same
# Please make sure you have compiled and installed pyds correctly.
# If the directory does not exist, please refer to sources/deepstream_python_apps/apps/README
cd /opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/bindings/build
# rebuild
make
# uninstall old version
pip uninstall pyds
# Reinstall the modified version
pip install ./pyds-xxxx-py3-none-linux_xxxx.whl
Okey !currently I am also using 7.0 . that error is not coming I able to set and install pyds properly.
Now video is saving .mp4 format but it’s has nothing(I mean 0 kb) file.
I want to know “ele.emit(‘start-sr’, a, 2, 7, None)”
in this what is 2 , 7 and None means and why frame is not saving if you can share something insides !!!
