We are trying to implement deepstream on an azure IOT edge device and we are particularly interested in the smart recording capabilities.
We are trying to use Gst-nvurisrcbin for it’s smart recording capabilities from Python. The documentation says how we can enable this capability but does not say how we can trigger it. How can we trigger from Python smart recording on this bin? Using gst-inspect-1.0 nvurisrcbin we can see it has two element actions “start-sr” and “stop-sr” but need the corresponding elements that can emit these types of signals. Are there any such elements available in the Python API?
• DeepStream Version
• TensorRT Version
GPU GeForce RTX 3080
DeepStream 6.3
• TensorRT Version
8.6.1.6
530.30.02 , CUDA Version: 12.1
How can we use Gst-nvurisrcbin, from Python, to use smart recording. Gst-nvurisrcbin — DeepStream 6.3 Release documentation shows that is supports this feature. Also we would like the events that trigger the recording to be read from Azure IoT Edge. Smart Video Record — DeepStream 6.3 Release documentation this document says it supports Azure IoT edpge protocol and there is also a proto buff lib that supports this protocol. How can we configure this.
We are not using any sample app since we do not need inference capabilities for now. It is a application/pipeline built from scracth based on python sample apps (deepstream-app3 and deepstream-app4) that uses two elements nvurisrcbin and a fake sink. We just want to record video based on an eventorder can still be used
here is a sample to start record by local event, you can port it to Python version. 1. enable smart-record.
g_object_set (G_OBJECT (uri_decode_bin), “smart-record”, 2, “smart-rec-dir-path”, “.”, NULL);
you can get the parameters explanation by “gst-inspect-1.0 nvurisrcbin”. 2. send start message
g_signal_emit_by_name(source_bin,“start-sr”, &sessId, 2, 7, NULL); 3. send stop message
g_signal_emit_by_name(source_bin,“stop-sr”, NULL);
Here is a Python sample to use nvurisrcbin for smart recording. 1. apply this patch for gpointer Python binding.
rebuild, reinstall pyds-*.whl. gpointer_bind.diff (1.4 KB)
2. send start/stop message
please refer to test3.py.diff (1.7 KB)
here is the start commandline: python3 deepstream_test_3.py -i rtsp://xx --no-display --file-loop --s
