Everything works as expected except that iframeinterval seems to be capped on 30 regardless of framerate - setting it to 1, 10 or 30 gives appropriate results, while everything above gives the same results as setting it to 30. I’ve also tried to use SliceIntraRefreshInterval instead of iframeinterval, and it behaves exactly the same. How can I make nvv4l2h265enc give me keyframe interval of, let’s say, 300 frames?
Do you use r32.6.1(Jetpack 4.6)? On the release, we add one property for setting IDR interval:
idrinterval : Encoding IDR Frame occurance frequency
flags: readable, writable, changeable only in NULL or READY state
Unsigned Integer. Range: 0 - 4294967295 Default: 256
I use L4T 32.4.4 [ JetPack 4.4.1 ]. The parameter you mentioned isn’t implemented there yet, it seems.
Can I assume that before idrinterval was added, iframeinterval implementation in nvv4l2h265enc was bugged and unable to be used properly for values above 30 (in omxh265enc such probem didn’t exist)?
With idrinterval added, do I always have to make it the same value as iframeinterval for values above 30 to work?
As you have noticed, the property is not implemented on Jetpack 4.4.1. If you need to set the property in your use-case, we would suggest upgrade to latest release.
I have noticed that, and I am planning to upgrade, but that still doesn’t answer my questions. I’ll repeat them here:
