Nvv4l2h265enc produces no valid frames for nvv4l2decoder
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) Jetpack 5.1 [L4T 35.2.1]
• TensorRT Version
• Issue Type( questions, new requirements, bugs) bug
Hi.
I am trying to ensure that multiple different sources can be encoded as the same h265 type to be decoded later in the pipeline. Part of this pipelines requires an encoding to h265 followed by an immediate decoding, as can be seen here: ... ! nvv4l2h265enc ! nvv4l2decoder ! ...
However, I get the following error:
ERROR: from element /GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0: No valid frames decoded before end of stream
Additional debug info:
gstvideodecoder.c(1140): gst_video_decoder_sink_event_default (): /GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0:
no valid frames found
This worked previously in Deepstream 5.1 and 6.0, however now doesn’t work in Deepstream 6.2.
This can be tested with the following command:
gst-launch-1.0 videotestsrc pattern=snow num-buffers=200 ! 'video/x-raw,width=1280,height=720' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvv4l2h265enc ! nvv4l2decoder ! nvv4l2h265enc ! 'video/x-h265,stream-format=byte-stream' ! h265parse ! mp4mux ! filesink location=./output.mp4
The expected behaviour is that a H265 video gets created, however the pipeline crashes.
I appreciate any suggestion on how to overcome this problem.
Thanks in advance,
Nicholas
The following pipelines work:
gst-launch-1.0 videotestsrc pattern=snow num-buffers=200 ! 'video/x-raw,width=1280,height=720' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvv4l2h265enc ! h265parse ! nvv4l2decoder ! fakesink
gst-launch-1.0 videotestsrc pattern=snow num-buffers=200 ! 'video/x-raw,width=1280,height=720' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=NV12' ! nvv4l2h265enc ! h265parse ! nvv4l2decoder ! nvv4l2h265enc ! 'video/x-h265,stream-format=byte-stream' ! h265parse ! mp4mux ! filesink location=./output.mp4
